hgkid1 Offline
#1 Posted : Monday, 25 February 2008 6:31:30 AM(UTC)
hgkid1
m trying to get the crank out of my 202. have got everything out accept for the timing case does the harmonic balancer come off in 2 parts ive used a gear puller to get it off but i cant get it behind the small part? how do i do this is there a knack? I'm stuck and its annoying the hell out of me koz its the only thing left on the block... please help.
#2 Posted : Monday, 25 February 2008 6:59:28 AM(UTC)
The balancer should come off as one piece, you might have ripped the outer off and now you will need to get the inner off, and a new balancer when you reassemble.
You should use a balancer puller not a gear puller to remive them, this is why it has hap
trubluhq Offline
#3 Posted : Monday, 25 February 2008 7:01:17 AM(UTC)
trubluhq
Some H/B have accessory rings ie for power steer. Remove the front ring if u do. Usually 4 bolts.
I assume you have removed the BIG bolt and washer on the H/B ?
If you have, put the bolt back on about half way. Like any H/B i use an adjustable pulle
hgkid1 Offline
#4 Posted : Monday, 25 February 2008 7:14:06 PM(UTC)
hgkid1
warren i think i have separated the inner from the outer on the harmonic balancer...
thanks for the advice... now that i have broken the old one is there some sort of fancier one that i can buy that will work better?
boom Offline
#5 Posted : Tuesday, 26 February 2008 3:39:59 AM(UTC)
boom
powerbond ones are good. ebay.
boom Offline
#6 Posted : Tuesday, 26 February 2008 3:39:59 AM(UTC)
boom
hgkid1 Offline
#7 Posted : Tuesday, 26 February 2008 7:49:54 AM(UTC)
hgkid1
ok cool im guessing thats a brand? where do i buy all these? do places like repco seel them over the counter or are they special order?
boom Offline
#8 Posted : Tuesday, 26 February 2008 8:39:23 AM(UTC)
boom
i think so. check ebay, i think i saw them there.
boom Offline
#9 Posted : Tuesday, 26 February 2008 8:39:23 AM(UTC)
boom
#10 Posted : Wednesday, 27 February 2008 9:35:12 AM(UTC)
there are 3 holes in the pulley, you make up a puller with a piece of about 9mm (3/6) plate, drill a hole in the centre and 3 holes around it matching the 3 in the puller, get 3 bolts that fit the 3 holes in the pulley and then get a larger bolt with a nu
