#1 Posted : Tuesday, 26 February 2008 4:33:59 AM(UTC)
Hi im trying to put on a gilmer belt drive to my chev small block,
but nothing seems to line up correctly.
its a short water pump kit.
the alt & the crank pulley line up correct.
but the water pump pulley sticks out to far so that it will not line up with the alt pulley.
im confused as the v belt lined up perfectly.
do i have the right pulley for the W-pump. or maybe a long one by mistake.
could some one tell me the dimensions of the pulley for the short setup ???
stumpy Offline
#2 Posted : Thursday, 28 February 2008 7:18:58 AM(UTC)
stumpy
Dyl,
I have exactly the same problem, alternator and crank pulley line up but pump pulley looks to be about 20 mm to long (low mount alt). When the belt is fitted it sits half way off the waterpump pulley towards the block and pretty much rubs on th
#3 Posted : Thursday, 28 February 2008 7:37:03 AM(UTC)
stumpy , i got mine in order , i used washers behind the alt bracket to make the whole thing stick out 3/4 of an inch forward. they dont all line up exact , but they are not supposed to ive heard. see how you go
stumpy Offline
#4 Posted : Thursday, 28 February 2008 7:57:08 AM(UTC)
stumpy
Dyl,
Thats a bit risky mate i reckon. If you give the thing a big rev, i bet it will flex and break its mount. I hope there is a better solution.
Stumpy
This page was generated in 0.094 seconds.
