#1 Posted : Tuesday, 26 February 2008 5:08:05 AM(UTC)
i have a rebuilt 308 for my hq, and i want to put a lumpy cam in it.i have recoed the heads...but i have been told to put on more performance heads to suit the cam,,is this right, if so what type of cam and heads should i get, and how much would they be.
?? I'm in in melb.
any sugestions
#2 Posted : Tuesday, 26 February 2008 5:17:58 AM(UTC)
The standard heads will be fine. Just don't go too wild in the cam. Stick to a street grind, eg a Crow 5602 or maybe 5666. And make sure you buy good quality valve springs to match the cam. If the engine doesn't have a new oil pump get one of those too. A
#3 Posted : Tuesday, 26 February 2008 5:17:58 AM(UTC)
The standard heads will be fine. Just dont go too wild in the cam. Stick to a street grind, eg a Crow 5602 or maybe 5666. And make sure you buy good quality valve springs to match the cam. If the engine doesnt have a new oil pump get one of those too. A s
boom Offline
#4 Posted : Tuesday, 26 February 2008 6:02:07 AM(UTC)
boom
a crane 284 cam with VN heads would be a very torquey motor with a huge topend.
boom Offline
#5 Posted : Tuesday, 26 February 2008 6:02:07 AM(UTC)
boom
#6 Posted : Tuesday, 26 February 2008 6:07:11 AM(UTC)
Agree, but not as torquey as early heads, as big port VN heads are too big for a stock stroke carbied 308, particularly when it's hard to get a dual plane manifold for VN heads. Boom, I think you have nailed it in previous posts, that the best bang for bu
#7 Posted : Tuesday, 26 February 2008 6:07:11 AM(UTC)
Agree, but not as torquey as early heads, as big port VN heads are too big for a stock stroke carbied 308, particularly when its hard to get a dual plane manifold for VN heads. Boom, I think you have nailed it in previous posts, that the best bang for buc
musksell Offline
#8 Posted : Tuesday, 26 February 2008 7:59:20 AM(UTC)
musksell
and if you read come racings website.....they will tell you why bother with a 350, when for a couple of hundred dollars more you can have there 95mm stroked 383 cubic incher....and it produces heaps more torque......according to them......I believe them.
boom Offline
#9 Posted : Tuesday, 26 February 2008 8:17:24 AM(UTC)
boom
boom Offline
#10 Posted : Tuesday, 26 February 2008 8:17:24 AM(UTC)
boom
boom Offline
#11 Posted : Tuesday, 26 February 2008 8:25:42 AM(UTC)
boom
Musksell- I totally agree, HOWEVER why stop at 383, when the new 396ci cranks are $1100, pistons and rods from the US shouldnt set you back more than another $1100, so in essence, it's actually cheaper to go 396 and source the parts yourself. and the amou
boom Offline
#12 Posted : Tuesday, 26 February 2008 8:25:42 AM(UTC)
boom
Musksell- I totally agree, HOWEVER why stop at 383, when the new 396ci cranks are $1100, pistons and rods from the US shouldnt set you back more than another $1100, so in essence, its actually cheaper to go 396 and source the parts yourself. and the amoun
#13 Posted : Tuesday, 26 February 2008 4:16:11 PM(UTC)
Now you are talking.
But that is a lot of money, when you already have a rebuilt engine. Now you have a dual plane which will improve the VN headed 308 down low. However they still have massive ports so you'd have to be careful with cam choice on a 308.
#14 Posted : Tuesday, 26 February 2008 4:16:11 PM(UTC)
But that is a lot of money, when you already have a rebuilt engine. Now you have a dual plane which will improve the VN headed 308 down low. However they still have massive ports so youd have to be careful with cam choice on a 308.
boom Offline
#15 Posted : Tuesday, 26 February 2008 5:46:31 PM(UTC)
boom
If you raise the comp to 9.55-10:1 a crane 288 solid will be perfect.
but, byron is correct about the massive ports, they are normally corrected by the bunch of bananas, so cam choice will be critical.
boom Offline
#16 Posted : Wednesday, 27 February 2008 7:18:22 AM(UTC)
boom
i would go with one of these but the question is: even when driven nicely, how muchpetrol are you going to use? 15-16 litres would still be fine, but going much higher than that would be a killer.
#17 Posted : Wednesday, 27 February 2008 7:55:54 AM(UTC)
thanks guys
the petrol is not a problem really, its just a occasional sunday cruiser.
i just want a tuff lumpy sound
boom Offline
#18 Posted : Wednesday, 27 February 2008 7:59:56 AM(UTC)
boom
id abandon my turbo 202 project and build an N/A 355, if someone bought the stuff. how much are EFI 202s going for these days?
Edited by user Wednesday, 27 February 2008 8:02:44 AM(UTC)  | Reason: Not specified
boom Offline
#19 Posted : Wednesday, 27 February 2008 7:59:56 AM(UTC)
boom
i'd abandon my turbo 202 project and build an N/A 355, if someone bought the stuff. how much are EFI 202s going for these days?
This page was generated in 0.125 seconds.
