blackdog4 Offline
#1 Posted : Tuesday, 26 February 2008 10:16:51 PM(UTC)
blackdog4
Hi guys, Can anyone tell me if a T5 out of a XF will fit in the place of a single rail behind a 351 cleveland or what mods will need to be done.
Cheers Paul
Edited by user Tuesday, 26 February 2008 10:24:02 PM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 5 March 2008 6:25:01 AM(UTC)
found out that the input shaft is the same but the bolt patern on the single rail and T5 are different. Dellows make a bellhousing to make it work with all my original gear.
Hope this helps anyone with a simular problem.
Cheers Paul
#3 Posted : Wednesday, 5 March 2008 8:38:46 PM(UTC)
might want to check out quick time bellhousings also may get more accesories with it
#4 Posted : Friday, 7 March 2008 9:49:23 PM(UTC)
And bear in mind that a 351 has far too much torque for any T5 to live very long behind unless you drive it like grandma all of the time.
Some peopl
#5 Posted : Sunday, 22 June 2008 2:35:10 PM(UTC)
1 bell housing hole is just offline. if u can drill . Ul save some money. Our Ea my little brother smocked the arse out of it. It had 500kms on the clock, When sold. Gearbox sweet. Now behind a 351 doen fine.
