hi i am wrecking a vn ss and was wondering what it would take to fit a vn injected v8 in my hz tonner/ does the the sump need changing / how hard is the wireing to change/ also do i need to mod the hump to fit t5 manual do i need a turbo crossmember hope you can help.
Hi pedro for a wiring loom see v6conversions.com the sump and the pickup needs to be HQ-Z get a VL external efi fuel pump and you may have to run a fuel return line depending on which state your in. Im in SA so didnt need an inspection so I disconnected t |
"Planet earth is the asylum to which the rest of the universe sends it's lunatics" Voltaire |
Search this forum for details. Been spoken about plenty of times. Also, for fuel Castle Auto Electrics sell a weld in ring for your fuel tank. You then use an in tank pump avoiding lots of hassles.
______________________________________________________ |
