basketcasebear Offline
#1 Posted : Friday, 29 February 2008 10:24:24 AM(UTC)
basketcasebear
hey yall,
I am trying to figure out the best way to lower my roof rack,, which is actually a roof for my campervan, which is actually a walk on floor as well..
now the problem I have is,,the gas struts lower it ok, untill it gets too about 45degrees, then they are not strong enough??
I thought of putting stronger struts on it,, but then it makes it too hard to pull down??
the scissor lifts on most pop tops, are for vertical lift??
my roof rack top, floor, folds down backwards on 4 arms?
I thought of a door closer??hhmm?/ to let it down slowly,,but i still need something to helplift back up untill the struts take the load?
I thought of torsion springs?? these might be the answer?? but i have tried the spring companies, and they either do big sway type ones,,or smaller ones in bulk amounts??
I am unable to use my ripper little winches, cause of lackof height??
any thought ideas?
greatly appreciated.
bcb
p.s
still not talking to cloudy, cause he outbid me in the auction!!
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
Edited by user Friday, 29 February 2008 10:25:35 AM(UTC)  | Reason: Not specified
DOH!!!
#2 Posted : Friday, 29 February 2008 10:41:38 AM(UTC)
have a look at air struts on each corner or maybe some type of pump up oil jack like a car bumper jack
#3 Posted : Friday, 29 February 2008 10:59:20 AM(UTC)
hey john,
thanks, but do not have the height..for car jacks..
something like 2 small pump up air shocks, only longer would do it?
normal ones are too big?
will keep looking, and will find the solution,
bcb
#4 Posted : Friday, 29 February 2008 11:06:24 AM(UTC)
john,,what are air struts??
bcb
jabba Offline
#5 Posted : Friday, 29 February 2008 5:08:00 PM(UTC)
jabba
Maybe a farm gate close spring? The ones which wind up as the gate open, then spring it shut (except mounted with the opposite twist so that they wind up as it shuts and release as it opens).
Keep the shiny
JBM Offline
#6 Posted : Friday, 29 February 2008 5:32:27 PM(UTC)
JBM
What about a counterweight of some type. A steel (lead) rod inside a pipe with a nylon rope attached could be mounted remotely so that it helps to get the load moving when you push it back up, only trouble is it needs to be about 75% of the load.
James
#7 Posted : Friday, 29 February 2008 7:53:55 PM(UTC)
basketcasebear
hey jabba, jbm,
I think I know what i need? the gate spring thingy sounds maybe about right/
but if you could imagine something like a mousetrap spring, only stronger?
I did think of something like welding clamp springs?
i will look at hardware tonigh
DOH!!!
VL05 Offline
#8 Posted : Friday, 29 February 2008 10:04:08 PM(UTC)
VL05
Springs are generally made of high tensile steel. Welding them will make them brittle, they will lose their elasticity or springiness around the heat affected zone and may crack.
WANTED: GTS rims, seats and mirrors to suit HJ.
VL05 Offline
#9 Posted : Friday, 29 February 2008 10:04:08 PM(UTC)
VL05
Springs are generally made of high tensile steel. Welding them will make them brittle, they will lose their elasticity or 'springiness' around the heat affected zone and may crack.
#10 Posted : Friday, 29 February 2008 11:27:26 PM(UTC)
basketcasebear
hey VL05,
you have got the wrong idea?
when i said welding clamps...i meant something that looks like welding clamps??
not actually welding the clamps?
hope this clarifies my poor english writing skills?
bcb
ptpro
DOH!!!
ozchevy Offline
#11 Posted : Saturday, 1 March 2008 12:42:00 AM(UTC)
ozchevy
Airbags perhaps,
They lay almost flat when deflated.
boom Offline
#12 Posted : Saturday, 1 March 2008 2:00:46 AM(UTC)
boom
You are a member of these groups:: Registered
airbag would work well, run a very small compressor to fill it. you could almost do this with the air shocks.
boom Offline
#13 Posted : Saturday, 1 March 2008 2:00:46 AM(UTC)
boom
ozchevy Offline
#14 Posted : Saturday, 1 March 2008 5:44:32 AM(UTC)
ozchevy
If you set up an airbag to do this, you can then make up a controller and valves to operate the airbag as a pressure device to raise the roof, and with the right pnuematic valves still use air pressure as a source to create vacuum to collapse the airbag.
#15 Posted : Saturday, 1 March 2008 7:24:05 AM(UTC)
Use the KISS principle. have a look at the tailgate spring on a horse float. It might just work.
Made the tailgate on my horse float a lot less hernia inducing.
Mr.Jones Offline
#16 Posted : Saturday, 1 March 2008 8:01:24 AM(UTC)
Mr.Jones
Damn BCB your going to have to put a blower on that 308 to cart all the extra weight around.
best of luck
Leroy
Voltaire
#17 Posted : Saturday, 1 March 2008 9:04:03 AM(UTC)
air struts are like the lift up struts on tailgates etc but run on air and can be pumped up, the strut collapses inside the outer housing so you need only half the length but if the strut can swivel you can have a longer one. you can get car jacks in all
#18 Posted : Saturday, 1 March 2008 11:17:16 AM(UTC)
basketcasebear
hey yall,
thanks so much for all your input.
i would love to have airbags, but it is about cost as well?
even an electric actuator is $140,,
I went to gate rural supplies and they had nothing! but I did grab a couple of el cheapo, welding clamps, and
DOH!!!
#19 Posted : Monday, 3 March 2008 2:20:35 AM(UTC)
basketcasebear
can i send a couple pics to one of you blokes, so you can put them up in this post?
I have tried and tried to figure out photobucket, but the chimp who designed it, didnt take my lack of intelligence into account.
bcb
ptpro
DOH!!!
Mechatron Offline
#20 Posted : Monday, 3 March 2008 2:26:12 AM(UTC)
Mechatron
hi bear i will do it
htpremier69 at gmail.com
Guest (7)
This page was generated in 0.100 seconds.
