#1 Posted : Sunday, 2 March 2008 7:44:41 AM(UTC)
hI i am trying to put a 307 chev into my HK prem
which was originally a 186.
i have a set of pacemakers to suit , but am just running into disaster.
the left side of the car (while sitting inside) fit very snug.
but the other side is chaos cant seem to fit round the steering box, also i think that my new CVR hi torque starter will not fit with the headers.
if anyone can help in the slightest , anything will be apprecaited
thank you
Edited by user Sunday, 2 March 2008 6:06:32 PM(UTC)  | Reason: Not specified
#2 Posted : Sunday, 2 March 2008 6:20:08 PM(UTC)
Make sure the engine mounts are right for a start. I am pretty sure the bigger one goes on the drivers side. (This is the adaptors, not the actual rubber engine mounts)
Take the starter off and all other hanging accesories. You may even need to discon
#3 Posted : Sunday, 2 March 2008 11:13:49 PM(UTC)
I think the Pacemakers also have clearance problems with the handbrake.
stressedout350 Offline
#4 Posted : Monday, 3 March 2008 1:45:51 AM(UTC)
stressedout350
I had Pacemakers on my HT 350, I had to remove some metal from the o/s chassis rail and seam weld it to give enough clearence for the pipes, also had to put a small dent in the pipe closest to the steering box for clearence also. O/s pipe cannot be instal
#5 Posted : Monday, 3 March 2008 8:08:12 AM(UTC)
hey thanks guys i got the extractors in , but the starter motor will far from go on again , i have the CVR hi torque , is this bigger than usual ???
let me know thanks
#6 Posted : Monday, 3 March 2008 8:41:23 AM(UTC)
stressedout350
I had no problems with starter motors, originally I had the standard starter but heat was a major problem, I installed a high torque starter, not sure of the brand, bought it second hand and had no problems, plenty of clearence.
Sorry I cant help.
#7 Posted : Monday, 3 March 2008 8:41:23 AM(UTC)
stressedout350
Sorry I can't help.
HG383PREM Offline
#8 Posted : Friday, 7 March 2008 12:02:55 AM(UTC)
HG383PREM
I had lots of issues with my hi-torque fitting in around things (383 chev stroker, 400 flexplate), in the end I had to strip the starter apart, swing the solenoid around to the sump, redrill the main mounting plate of the starter so it would hold together
hkpremier1968 Offline
#9 Posted : Friday, 7 March 2008 12:27:52 AM(UTC)
hkpremier1968
I had the same problem with my Premier. 307, Pacemakers, Hi-torque starter = lots of problems. The meshing was the bigest problem I also moved the starter around on the mounting. Cheers.
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
UNRULY Offline
#10 Posted : Monday, 24 March 2008 7:34:33 PM(UTC)
UNRULY
My HG Prem had a few clearance issues with the off the shelf pacemakers. Firstly I had to move the handbrake wheel back about an inch (welded it back on). Then I had to take the grinder to the starter motor mounting block to clear the pipes. I'm pretty
UNRULY Offline
#11 Posted : Monday, 24 March 2008 7:34:33 PM(UTC)
UNRULY
My HG Prem had a few clearance issues with the off the shelf pacemakers. Firstly I had to move the handbrake wheel back about an inch (welded it back on). Then I had to take the grinder to the starter motor mounting block to clear the pipes. Im pretty s
#12 Posted : Tuesday, 25 March 2008 2:40:54 AM(UTC)
I use the CVR "Maxium" mini starter for Chevs in tight places like HK-HG with extractors. They are ever smaller than the usual mini starter with more grunt as well (3.1hp). You can spin the starter around on the mounting flange and they weigh even less...
This page was generated in 0.184 seconds.
