v8cruisin Offline
#1 Posted : Saturday, 17 November 2007 12:31:05 AM(UTC)
v8cruisin
Hi people. I have a HZ ute that is already setup for SBC and th400. I've got a 307 chev to put in it to get it drivable. I also have a saginaw 4 speed which appears to be in good condition. I dont have flywheel, clutch + presure plate. has fork and bearing tho. Do I need to buy a hydraulic clutch conversion kit (dellow sell $395) to make the gearbox work in my ute? Are there parts from other holdens (eg with muncie box) that I can use for this conversion? I can send pics if required. I'd appreciate any help.
From Roy
#2 Posted : Saturday, 17 November 2007 2:50:32 AM(UTC)
TH350 crossmember out of an early WB Statesman will come close to fitting the Saginaw. Just shorten it at each end to fit the ute. TH400 speedo cable. Aussie 4spd or trimatic tailshaft. And an aftermarket shifter. Standard Chevy flywheel but be careful of
v8cruisin Offline
#3 Posted : Saturday, 17 November 2007 5:59:50 AM(UTC)
v8cruisin
Thanks for that. my ute was factory manual and still has pedal (which i was surprised to find when I pulled the carpet up).it is a small bellhousing, a 14 flywheel wont fit in it.
Mounting box and modifying driveshaft wont be a problem. If it is a HK b
#4 Posted : Saturday, 17 November 2007 6:07:45 AM(UTC)
Unless it's a late HZ pedal it won't suit a WB cable setup. If it is a HK style bellhousing you'll need a 10.5" flywheel. Plus the bellhousing will be a push fork, but you need a pull fork for a cable clutch. You can fit a hydraulic setup but it does get
#5 Posted : Saturday, 17 November 2007 6:07:45 AM(UTC)
Unless its a late HZ pedal it wont suit a WB cable setup. If it is a HK style bellhousing youll need a 10.5" flywheel. Plus the bellhousing will be a push fork, but you need a pull fork for a cable clutch. You can fit a hydraulic setup but it does get in
