#1 Posted : Sunday, 18 November 2007 1:24:31 AM(UTC)
Im having trouble trying to put new glass into the quarter window section of the back seat... on the left door...
The seals are hard to slip into the position of the window since the glass makes it difficult...
HELP!
#2 Posted : Sunday, 23 December 2007 1:06:28 PM(UTC)
U need to remove the rear door window assembly first before you can install the quater glass..Sorry theres no other way...
HZute-efi-VS5L Offline
#3 Posted : Sunday, 23 December 2007 9:19:23 PM(UTC)
HZute-efi-VS5L
if its the one in the door you need to remove the main window that winds up and down first. then fit the 1/4 window. too easy.
if its the one in the back 1/4 pannel not the door than you need the correct heat glue seal thingo. like in front windows.
Edited by user Sunday, 23 December 2007 9:20:08 PM(UTC)  | Reason: Not specified
www.stickthisdecals.com.au
