bundybluedog Offline
#1 Posted : Monday, 3 March 2008 8:24:50 AM(UTC)
bundybluedog
do 235/308 extracors fit VN and up style heads?
also apart from apart from the early pre pollution 253/308 heads, is there much diferance between red/blue/black pollution type V8 heads?
do they all use the same inlet and head gaskets? and what were the best pollution style heads to use apart from HDT or HSV.
Someone told me the blue and black heads used differant inlet manifold gasket so i wanna confirm this with you guys.
cheers dan
JBM Offline
#2 Posted : Monday, 3 March 2008 8:35:03 AM(UTC)
JBM
Pre VN heads have different port layout to the VN, VN inlet and outlet ports are evenly spaced, to put VN heads on early blocks you need a VN inlet, exhaust and cam.
There are 2 basic heads types for the early heads, non EGR (red) and EGR (blue and black
boom Offline
#3 Posted : Monday, 3 March 2008 8:39:23 AM(UTC)
boom
the reason they used the bananas wasnt to block airflow, it was because the bananas produce great torque down low.
Having said that, im going to go with a Torque power single plane on the Injected 355 im building. just gotta pick up the block, and im in
boom Offline
#4 Posted : Monday, 3 March 2008 8:39:23 AM(UTC)
boom
the reason they used the bananas wasn't to block airflow, it was because the bananas produce great torque down low.
Having said that, i'm going to go with a Torque power single plane on the Injected 355 im building. just gotta pick up the block, and im i
#5 Posted : Monday, 3 March 2008 7:46:37 PM(UTC)
boom Offline
#6 Posted : Tuesday, 4 March 2008 7:21:33 AM(UTC)
boom
im dropping the turbo 202 project, and im going straight to stroker holden V8, im using VN heads (maybe yella terra -9s down the track) and a single plane torque power or harrop manifold (apparantly torque power makes more torque, but harrop makes more ou
boom Offline
#7 Posted : Tuesday, 4 March 2008 7:21:33 AM(UTC)
boom
im dropping the turbo 202 project, and im going straight to stroker holden V8, i'm using VN heads (maybe yella terra -9s down the track) and a single plane torque power or harrop manifold (apparantly torque power makes more torque, but harrop makes more o
#8 Posted : Tuesday, 4 March 2008 9:26:29 PM(UTC)
bundybluedog
thats for all that guys, you like you stokers hey boom im thinking i might go the 383 chev for my monaro i wanna try for the mid 11 seconds. would i need to strengthen the subframe fo that?
How far into your 202 turbo project did you get? did you make up
Edited by user Tuesday, 4 March 2008 9:29:17 PM(UTC)  | Reason: Not specified
#9 Posted : Tuesday, 4 March 2008 10:24:12 PM(UTC)
Don't take this as gospel, but Holden built HK-HG for a SBC, and a 400 Chev is a small block, so a stroked 350 (377) shouldn't be a problem. I know a 400 is a torquier engine than a 350 but HK-HG are very strong in the subframe, so I don't imagine you'd h
#10 Posted : Tuesday, 4 March 2008 10:24:12 PM(UTC)
Dont take this as gospel, but Holden built HK-HG for a SBC, and a 400 Chev is a small block, so a stroked 350 (377) shouldnt be a problem. I know a 400 is a torquier engine than a 350 but HK-HG are very strong in the subframe, so I dont imagine youd have
#11 Posted : Tuesday, 4 March 2008 10:39:17 PM(UTC)
bundybluedog
Thanks for that byron 383 seems to be the way to go for power and reliabilty, i have a 8.5 inch 10 bolt from a camaro will be 3.78 posi i think it should be strong enough i could go the 9 inch or a 12 bolt as the are cheaper and the comaro one dont need s
boom Offline
#12 Posted : Wednesday, 5 March 2008 2:25:57 AM(UTC)
boom
yep, 383 definitely. you can build a 400+ 383 CHEV for less than 5grand.
I'm only going holden because it's a bitch to put into a commodore.
I didn't get THAT far into the turbo 6 project. I bought the turbo, injected motor, and a few other bits. i
boom Offline
#13 Posted : Wednesday, 5 March 2008 2:25:57 AM(UTC)
boom
Im only going holden because its a bitch to put into a commodore.
I didnt get THAT far into the turbo 6 project. I bought the turbo, injected motor, and a few other bits. i did
#14 Posted : Wednesday, 5 March 2008 4:54:23 AM(UTC)
Edited by user Wednesday, 5 March 2008 4:57:11 AM(UTC)  | Reason: Not specified
boom Offline
#15 Posted : Wednesday, 5 March 2008 5:02:33 AM(UTC)
boom
you could always cut down a borg warner housing from a commodore and get the axles shortened and resplined. would cost maybe $700 all up.
very strong diff, the VL turbo guys are running nines with them in the back.
If nissan mot
boom Offline
#16 Posted : Wednesday, 5 March 2008 5:04:15 AM(UTC)
boom
Originally posted by Byron Rich
Warwick Yellow GTS427.
#17 Posted : Wednesday, 5 March 2008 5:09:49 AM(UTC)
A VL diff is actually narrower than a HK-HG. And a 377-380 cube small block with close to 500ft-lb or torque would probably bust those just as quick as a Chev 10-bolt. My mates HK used to destroy 9" centres at first too, until he put a minispool in. Never
#18 Posted : Wednesday, 5 March 2008 5:09:49 AM(UTC)
A VL diff is actually narrower than a HK-HG. And a 377-380 cube small block with close to 500ft-lb or torque would probably bust those just as quick as a Chev 10-bolt. My mate's HK used to destroy 9" centres at first too, until he put a minispool in. Neve
#19 Posted : Wednesday, 5 March 2008 5:27:10 AM(UTC)
Originally posted by boom
boom Offline
#20 Posted : Wednesday, 5 March 2008 5:54:28 AM(UTC)
boom
cool. i don't know that he'd snap the diff, i know many 700+hp v8s running themnm
Guest (11)
This page was generated in 0.100 seconds.
