#1 Posted : Tuesday, 4 March 2008 12:15:47 AM(UTC)
I have a 1993 Holden Stationwagon, i have changed the fuel filter, oil filter, oil, air filter, sparkplugs and leads and also re-adjusted the throttle body to try and stop a shudder that occurs when idleing. When the car idles it will shudder intermidantly but violently and sometimes will stall after being driven for a while, but will always start immedatly. i have a suspicion that it may be the injectors the are fouled up, but i really have no idea. Any help would be much appreciated.
#2 Posted : Wednesday, 5 March 2008 12:38:58 AM(UTC)
Sounds like the IAC (idle air control) solenoid thats bolted on to the firewall side of the throttle body could use a clean.
Some people say I am out
#3 Posted : Wednesday, 5 March 2008 12:38:58 AM(UTC)
Sounds like the IAC (idle air control) solenoid that's bolted on to the firewall side of the throttle body could use a clean.
