htprem350 Offline
#1 Posted : Thursday, 6 March 2008 9:34:57 PM(UTC)
htprem350
Hi all,
Just wondering if any of you guys know if a 9inch diff clears the fuel tank in a HT Premier when the cars is lowered 3 inches. I haven't put the diff or the fuel tank in yet but have been told i might have dramas.
Has anyone out there experienced this please.
hkpremier1968 Offline
#2 Posted : Thursday, 6 March 2008 10:59:36 PM(UTC)
hkpremier1968
Hi again, I have seen this combo punch holes in the fuel tank being this low. Why 3 inches? The way you might be able to get around this is to play with the bump stops. I know some wagons utes and vans have a taller bump stop plate on the diff housing. Th
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
htprem350 Offline
#3 Posted : Thursday, 6 March 2008 11:17:06 PM(UTC)
htprem350
Thanks for the info mate,
I want the car sitting at 3 inches and have already had the springs done and 9inch built.
I am contemplating having the fuel tank modified at the front to accommodate for clearance but was not sure if anyone knew how much roo
#4 Posted : Thursday, 6 March 2008 11:27:28 PM(UTC)
hkpremier1968
Hi, there is not much room at all!! The factory fitted 10 bolt is not much bigger than the bango and holden made the tanks for those cars with a bolge at the front (around 2") for clearance. Cheers.
htprem350 Offline
#5 Posted : Thursday, 6 March 2008 11:35:31 PM(UTC)
htprem350
Yep,
Gunna have to do some creative thinking to make this one work.
Cheers mate
#6 Posted : Thursday, 6 March 2008 11:48:46 PM(UTC)
Hump in HK-HG is designed for 12-bolt clearance. You dont need it with a 10-bolt.
#7 Posted : Thursday, 6 March 2008 11:48:46 PM(UTC)
Hump in HK-HG is designed for 12-bolt clearance. You don't need it with a 10-bolt.
#8 Posted : Friday, 7 March 2008 12:06:53 AM(UTC)
hkpremier1968
Hi Byron, 12 bolt is the amount of bolds around the crown wheel. In the HK HT HG's they had some of these but people think the are only 10 bolts as this is the amount of backing plate bolts. The HK HT HG 10 and 12 bolts are all the same size on the outsid
#9 Posted : Friday, 7 March 2008 12:06:53 AM(UTC)
hkpremier1968
Hi Byron, 12 bolt is the amount of bolds around the crown wheel. In the HK HT HGs they had some of these but people think the are only 10 bolts as this is the amount of backing plate bolts. The HK HT HG 10 and 12 bolts are all the same size on the outside
#10 Posted : Friday, 7 March 2008 6:45:30 AM(UTC)
No.
Davesmonaro68 Offline
#11 Posted : Friday, 7 March 2008 7:16:30 AM(UTC)
Davesmonaro68
A 12 bolt diff has what it says - 12 bolts and is a huge diff thats what the bulge was for definately not for the 10 bolt . Also just because a car comes with a bulge in the tank area dont mean it came with a 12 bolt, could have had a 10 bolt or banjo dif
MONARO!!WHERE!!NICE
#12 Posted : Friday, 7 March 2008 7:16:30 AM(UTC)
Davesmonaro68
A 12 bolt diff has what it says - 12 bolts and is a huge diff thats what the bulge was for definately not for the 10 bolt . Also just because a car comes with a bulge in the tank area don't mean it came with a 12 bolt, could have had a 10 bolt or banjo di
MONARO!!WHERE!!NICE
ozchevy Offline
#13 Posted : Friday, 7 March 2008 7:21:58 AM(UTC)
ozchevy
I suggest you have another good look at the physical differences of 10 and 12 bolt diffs. Nothing is alike.
#14 Posted : Friday, 7 March 2008 7:53:38 AM(UTC)
hkpremier1968
Hi, have a look at page 187 of the Monaro Story. Cheers.
#15 Posted : Friday, 7 March 2008 4:21:02 PM(UTC)
Page 188 and 189 you mean? The 12 bolt is much different to look at than a 10-bolt. Sort of like looking at a banjo and a 9" together, but not quite as big a difference.
If we all had the same (g
