les Offline
#1 Posted : Friday, 14 March 2008 2:19:12 AM(UTC)
les
Is there any call for HK GTS road wheels, we have a chance to make some but are unsure if there is a call on them. BTW do the only fit HK or do the also fit HT HG
hkpremier1968 Offline
#2 Posted : Friday, 14 March 2008 3:23:57 AM(UTC)
hkpremier1968
Hi Les, just a quick note. If you make them to the same spec as Holden did and you put them on a car with tramp rods they might rub the rods. Holden made a spacer that was fitted when the car came in for service as they found the tyers rubbed sometimes. I
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#3 Posted : Friday, 14 March 2008 7:15:16 AM(UTC)
There are 5 basic different rims:
HK 5";
HK 6";
HT/G 5";
HT/G 6"
HT/HG GTS350 manual rims (slotted and lightweight).
All are interchangeable ie they fit, but HK 6" wont fit a car with radius rods unless wheel spacers are fitted.
ROH still mak
Edited by user Friday, 14 March 2008 7:16:17 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 14 March 2008 7:15:16 AM(UTC)
HK 5";
HK 6";
HT/G 5";
HT/G 6"
All are interchangeable ie they fit, but HK 6" won't fit a car with radius rods unless wheel spacers are fitted.
ROH still ma
#5 Posted : Friday, 14 March 2008 9:29:05 AM(UTC)
hkpremier1968
I think there was also a so called HT Rally rim that had the centre spotwelded as normal and seam welded in the rear. Cheers.
#6 Posted : Friday, 14 March 2008 5:05:26 PM(UTC)
There are a few variations of the same rim. Some HK 6" rims are spotted and welded as well.
#7 Posted : Friday, 14 March 2008 7:16:27 PM(UTC)
hkpremier1968
The 6 original 6" HK rims I have are only spot welded. I was told years ago by memory the HT's could have had 4 or 5 slots where the centre is welded to the rim and this could tell you if it was a Rally rim. But I could be wrong. Cheers.
Lots of cars,
#8 Posted : Friday, 14 March 2008 7:16:27 PM(UTC)
hkpremier1968
The 6 original 6" HK rims I have are only spot welded. I was told years ago by memory the HTs could have had 4 or 5 slots where the centre is welded to the rim and this could tell you if it was a Rally rim. But I could be wrong. Cheers.
Lots of cars, L
81837 Offline
#9 Posted : Friday, 14 March 2008 9:26:10 PM(UTC)
81837
Byron, where are the slots in the GTS350 manual wheels?
I have a set of 6" wheels, spot welded only, solid centres apart from the four gaps around the circumference between the welds that are stamped 6.JJ 14 7/70 HOLDEN 22-2. I wouldnt say they are light
81837 Offline
#10 Posted : Friday, 14 March 2008 9:26:10 PM(UTC)
81837
I have a set of 6" wheels, spot welded only, solid centres apart from the four gaps around the circumference between the welds that are stamped 6.JJ 14 7/70 HOLDEN 22-2. I wouldn't say they are ligh
81837 Offline
#11 Posted : Friday, 14 March 2008 9:27:44 PM(UTC)
81837
81837 Offline
#12 Posted : Friday, 14 March 2008 9:27:44 PM(UTC)
81837
#13 Posted : Saturday, 15 March 2008 2:19:47 AM(UTC)
The HT and HG 350 manual wheels look the same as the 350 auto and other 6" HT/G rims except cooling slots are cut like in a HK. I always thought the lightweight thing was a myth too, but I am assured by a guru (1 of two) that he has weighed them against n
81837 Offline
#14 Posted : Saturday, 15 March 2008 8:15:13 AM(UTC)
81837
Can anyone show me a photo of a slotted wheel please?
[email protected]
#15 Posted : Saturday, 15 March 2008 9:13:08 AM(UTC)
It is quite simple. The area around the wheel nuts looks like any LC/HT on Holden wheel, including Commodore.
Then there are 8 oval slots cut into the outer centre.
No other wheel has this combination
Warren
#16 Posted : Sunday, 16 March 2008 2:19:58 AM(UTC)
hey 81837 how did you get name like that if you dont even know what a 818 rim looks like. shame on you
adam PERTH Offline
#17 Posted : Sunday, 16 March 2008 6:41:02 AM(UTC)
adam PERTH
were the Sankey Benson / Tasmans and option on HKTG?
factory or dealer?
A1 Bogan.
#18 Posted : Sunday, 16 March 2008 5:07:26 PM(UTC)
The first alloy whel option from hlden was th XU1 sprintmaster, the next being the SL/E.
Dealers could fit anything they wanted. If yor car was fitted with 6 alloys though the dealer would have more than likely ordered the car with 6" rims so that he o
#19 Posted : Sunday, 16 March 2008 5:07:26 PM(UTC)
Dealers could fit anything they wanted. If yor car was fitted with 6' alloys though the dealer would have more than likely ordered the car with 6" rims so that he
This page was generated in 0.109 seconds.
