dagwoodone Offline
#1 Posted : Friday, 14 March 2008 3:30:06 AM(UTC)
dagwoodone
have just bought a lsd centre out of a hz and all the spider gear teeth are stripped ,Mustve been one good burn out . The question i ask is the banjo diff centre spider gears the same as the lsd ones ive looked at a banjo and without pulling both apart they look the same ??? any help ? cheers Dazza
#2 Posted : Friday, 14 March 2008 7:10:42 AM(UTC)
The planetary gears in an LSD should be the same as a non-LSD Salisbury. The Sun gears are different though (the ones with the axles in them).
If we all had the same (good) taste, who would buy a
dagwoodone Offline
#3 Posted : Saturday, 15 March 2008 2:09:06 AM(UTC)
dagwoodone
Thanks Byron thought they looked the same just didnt want to pull all appart and have diff stuff all over the place if they wernt the same ...Cheers Dazza
#4 Posted : Saturday, 15 March 2008 2:20:54 AM(UTC)
I think you misread me. I dont think they are the same as banjo, just LSD and non LSD Salisbury.
#5 Posted : Saturday, 15 March 2008 2:20:54 AM(UTC)
I think you misread me. I don't think they are the same as banjo, just LSD and non LSD Salisbury.
dagwoodone Offline
#6 Posted : Sunday, 16 March 2008 8:36:38 PM(UTC)
dagwoodone
Thats cool too i am going to build a lsd for my hz as its a single spinner so i got a lsd centre so if they are the same then thats ok as i will give it to my diff guy to rebuild. Thanks again for your input ...Holden On Dazza
