#1 Posted : Friday, 14 March 2008 9:29:49 PM(UTC)
were all 10 bolt difs 28 spline or 31?
#2 Posted : Friday, 14 March 2008 9:32:21 PM(UTC)
28 spline
bundybluedog Offline
#3 Posted : Saturday, 15 March 2008 6:23:17 AM(UTC)
bundybluedog
8.5 inch 10 bolt is 30 i think the smaller 10 bolts are 28 i think even a 26
#4 Posted : Saturday, 15 March 2008 9:52:32 PM(UTC)
bundy you are saying HQ on, are 28 spline.
And HK-T-G are 30 spline?
#5 Posted : Sunday, 16 March 2008 8:23:13 AM(UTC)
bundybluedog
yep the hk ht hg were 8.5 inch and the hq on, i think were 7.5 inch im not an expert just a beginer and then 10 bolt 6 cyl on the commodore were a bit smaller to
#6 Posted : Monday, 17 March 2008 10:35:16 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi Guys.
There were basically 4 different diffs in these models, when you exclude the 7" Banjo style.
They were:
1, GM US 10-bolt (8.2") HK/T/HG only - 28-spline
2. GM US 12-bolt HK/T GTS 350 manual option only - 30-spline
3. GM-H 'Large' 10-bol
Edited by user Monday, 17 March 2008 10:39:33 PM(UTC)  | Reason: Not specified
#7 Posted : Monday, 17 March 2008 10:35:16 PM(UTC)
Hi Guys.
They were:
3. GM-H Large 10-bolt
#8 Posted : Thursday, 20 March 2008 12:46:30 AM(UTC)
True DR terry. but number 4 i thought was called 8 bolt?
The Geminis, i thought had a long alloy snout to the tail shaft.
I think banjo diff from HJ on got 23 spline, like the SLR 5.0L torana, and maybe the 1975 on torana 6 cyl?
#9 Posted : Thursday, 20 March 2008 12:52:54 AM(UTC)
And in number 4 it's 4.2L v8 got 8 bolt. just to be sure to be sure.
#10 Posted : Thursday, 20 March 2008 12:52:54 AM(UTC)
And in number 4 its 4.2L v8 got 8 bolt. just to be sure to be sure.
#11 Posted : Thursday, 20 March 2008 1:19:22 AM(UTC)
Hi Rosie.
I've never heard the term 8-bolt for the Holden Small Salisbury. GM-H use the terms small & large, but then later call them 178 mm & 190 mm respectively.
The Gemini diff does use 'Torque Tube Drive' but it is still a Holden Small Salisbury
#12 Posted : Thursday, 20 March 2008 1:19:22 AM(UTC)
Hi Rosie.
Ive never heard the term 8-bolt for the Holden Small Salisbury. GM-H use the terms small & large, but then later call them 178 mm & 190 mm respectively.
The Gemini diff does use Torque Tube Drive but it is still a Holden Small Salisbury. A
adam PERTH Offline
#13 Posted : Thursday, 20 March 2008 2:11:08 AM(UTC)
adam PERTH
the "8 bolt" is used in the wrecking game over here in the west.
I know, strictly speaking, it has 10 bolts too, but is used to ID the small round sailbury, from the large oval sailsbury.
A1 Bogan.
#14 Posted : Thursday, 20 March 2008 2:32:13 AM(UTC)
Whoa... Small Salisbury behind WB 253 ute and van? If this is true then I have learned another Holden fact today! I'm sure though i've pulled large Salisburys from low kM WB Kingswood V8 utes in the early 90's.
Large Salisbury was also standard fitment o
#15 Posted : Thursday, 20 March 2008 2:32:13 AM(UTC)
Whoa... Small Salisbury behind WB 253 ute and van? If this is true then I have learned another Holden fact today! Im sure though ive pulled large Salisburys from low kM WB Kingswood V8 utes in the early 90s.
Large Salisbury was also standard fitment on V
adam PERTH Offline
#16 Posted : Saturday, 22 March 2008 6:20:06 AM(UTC)
adam PERTH
I am with bryon,
L36 goes with a Large oval 10 bolt from my experience.
A1 Bogan.
#17 Posted : Saturday, 22 March 2008 10:16:55 PM(UTC)
I remember my cousin bought one of the last of WB V8 4.2L utes brand new, it had a small salisbury. i thought he had been riped off. but it's true, they got the small salisbury. it was not a borg warner.
#18 Posted : Saturday, 22 March 2008 10:16:55 PM(UTC)
I remember my cousin bought one of the last of WB V8 4.2L utes brand new, it had a small salisbury. i thought he had been riped off. but its true, they got the small salisbury. it was not a borg warner.
