adam PERTH Offline
#1 Posted : Wednesday, 19 March 2008 11:35:52 PM(UTC)
adam PERTH
Hey guys.
got an 6 cyl XY fairmont and wanna put the 351C / FMX / 9" in it outta a ZJ fairlane.
The problem is, will an FMX fit into the XY trans tunnel?
will the diff swap be straight forward?
any other tips.?
What rims look best for old skool?
5 slot / globes / 12 slotter?
i know its a personal choice, just some opinions from ford freaks would be great.
A1 Bogan.
Edited by user Wednesday, 19 March 2008 11:39:01 PM(UTC)  | Reason: Not specified
ZC-Cruiser Offline
#2 Posted : Wednesday, 19 March 2008 11:43:29 PM(UTC)
ZC-Cruiser
! - Globes
2 - 5 Slot
3 - 12 Slot
It's good to honk in a Henry
#3 Posted : Thursday, 20 March 2008 1:18:58 AM(UTC)
Go for it FMX will fit.
Diff out of a ZJ = XD.it should be a B/W 4 star, behind a 351, not a 9".
The last 9" diff were in XC-ZH fairlane and P6 LTD.
Nothing is straight forward.
adam PERTH Offline
#4 Posted : Thursday, 20 March 2008 2:05:34 AM(UTC)
adam PERTH
so my diff outta ZJ an 8 3/4 or ??
what about tailshaft?
A1 Bogan.
#5 Posted : Thursday, 20 March 2008 7:32:53 AM(UTC)
has it got a steel plate bolted to the back of the diff, then it's a borg warner. if it's got a banjo type, with bolt's on the tail shaft side it should be a 9".
#6 Posted : Friday, 21 March 2008 2:37:46 AM(UTC)
Hello Adam,
Everything will fit with the exception of:
1/. Tailshaft will be too long but the xy one should fit.
2/. The diff will fit but is 2 inches wider than the XY unit. Spring saddles are the same distance apart though. Being 351
Edited by user Friday, 21 March 2008 2:38:51 AM(UTC)  | Reason: Not specified
#7 Posted : Friday, 21 March 2008 2:42:52 AM(UTC)
The diff in your ZJ should be a Borg Warner 78 (8 3/4 is a Dodge diff) if it's the original 351 unit it will be a 4 pinion 28 spline LS unit probably 2.77:1.
If it's a 302 unit it will be a 2 pinion 25 spline unit no stronger than the XY one but st
This page was generated in 0.158 seconds.
