#1 Posted : Thursday, 20 March 2008 1:54:33 PM(UTC)
is it possible to ID a YT head when still fitted to a motor? just cause its painted yellow doesn't make it so.
anyone know how to tell? cheers
boom Offline
#2 Posted : Thursday, 20 March 2008 7:55:55 PM(UTC)
boom
what motor is it?
In cubes we trust.
Edited by user Thursday, 20 March 2008 7:57:00 PM(UTC)  | Reason: Not specified
#3 Posted : Saturday, 22 March 2008 12:01:24 AM(UTC)
186P block. any info appreciated
boom Offline
#4 Posted : Saturday, 22 March 2008 1:07:17 AM(UTC)
boom
o.k, take the inlet manifold off, and look at the ports, most yt heads have the inlet bosses removed. take a look at a standard one and compare. on standard heads the boss block half of the inlet. also yt heads have a little more porting.
boom Offline
#5 Posted : Saturday, 22 March 2008 2:06:26 AM(UTC)
boom
peter_flane Offline
#6 Posted : Saturday, 22 March 2008 6:41:18 AM(UTC)
peter_flane
If the head is as boom describes, it can be done by anyone, it does not have to be a Yella Terra head, although the type of work done where the inlet centre cast is removed and a tube is inserted is the same type of work done to the commonly named stage 3
peter_flane Offline
#7 Posted : Saturday, 22 March 2008 6:41:18 AM(UTC)
peter_flane
If the head is as boom describes, it can be done by anyone, it does not have to be a 'Yella Terra' head, although the type of work done where the inlet centre cast is removed and a tube is inserted is the same type of work done to the commonly named 'stag
#8 Posted : Saturday, 22 March 2008 7:12:11 PM(UTC)
If you look here http://gallery.oldholden...Tech/Engines/red+heads/
I have pictures showing a std head and a couple of stages of port work on two other
heads. I there I have listed them as stages but that is still being debated as to what
is w
This page was generated in 0.137 seconds.
