#1 Posted : Saturday, 22 March 2008 11:44:55 PM(UTC)
Hi, new to the forum.
I have just changed the dizzy on my vs 5.0, but I have put the sparkplugs in the wrong order.
It doesn't back fire when I start it, but it is rough.
Could you please let me know what it the correct order?
bundybluedog Offline
#2 Posted : Sunday, 23 March 2008 1:44:39 AM(UTC)
bundybluedog
find TDC on number 1 piston look at which lead the rotar button is pointing to, then put them in firing order at both ends plugs and dizzy cap. also make sure your not 180 degrees out i did that on a dizzy change ona 253 i had. your timing marks on your
Roddo Offline
#3 Posted : Saturday, 29 March 2008 1:49:49 AM(UTC)
Roddo
firing order is 1 2 7 8 4 5 6 3, if bundys directions dont work as well, you may be 1 tooth out on the dissy gear, can be tricky to get right.
