$350 for a very quick sale. And it was snapped up in a flash.
Thanks: 1 times Was thanked: 558 time(s) in 533 post(s)
Yes Chevs were an easy and cheap conversion for pre about 1980 Jags. All you really had to do was bolt the tail end of a Jaguar TH400 onto a Chev one and put in engine mounts, and plumb it all up. But if you want to easily pass later pollution ADRs a Hold |
Yes Chevs were an easy and cheap conversion for pre about 1980 Jags. All you really had to do was bolt the tail end of a Jaguar TH400 onto a Chev one and put in engine mounts, and plumb it all up. But if you want to easily pass later pollution ADR's a Hol |
quote: Originally posted by Byron Rich
although as you get bigger in cubes the standard manifold starts to get restrictive - b
I'd be sloting in a chev with the 700 and leave the diff
Id be sloting in a chev with the 700 and leave the diff
