I have just installed a HEI dizzy in my 305 sb HQ statesman, I have been told that the original points power feed wire supplies 12v on start up but once running only has an output of 9.6v Has any one else heard of this? dizzy came with no instructions so am not to sure on wiring, is it as simple as pluging the 3 wires from the base into the cap and connecting the single original(+) dizzy wire for it to run, cheers wayne
There is a resistor in the wiring harness, so you need to bypass this wire ie run a wire straight from the ignition switch to the dizzy.
_______________________________________________________ If we all had the same (good) taste, who would buy all the |
Its a pink wire i believe. Its got resistance wire written on it Cheers.
It's a pink wire i believe. Its got resistance wire written on it Cheers.
That's the one.
Thats the one.
