#1 Posted : Monday, 24 March 2008 5:16:30 PM(UTC)
I have just installed a HEI dizzy in my 305 sb HQ statesman, I have been told that the original points power feed wire supplies 12v on start up but once running only has an output of 9.6v
Has any one else heard of this? dizzy came with no instructions so am not to sure on wiring, is it as simple as pluging the 3 wires from the base into the cap and connecting the single original(+) dizzy wire for it to run,
cheers wayne
#2 Posted : Monday, 24 March 2008 8:28:45 PM(UTC)
There is a resistor in the wiring harness, so you need to bypass this wire ie run a wire straight from the ignition switch to the dizzy.
If we all had the same (good) taste, who would buy all the
#3 Posted : Monday, 24 March 2008 8:48:33 PM(UTC)
Its a pink wire i believe. Its got resistance wire written on it
Cheers.
#4 Posted : Monday, 24 March 2008 8:48:33 PM(UTC)
It's a pink wire i believe. Its got resistance wire written on it
Cheers.
#5 Posted : Monday, 24 March 2008 9:09:36 PM(UTC)
That's the one.
#6 Posted : Monday, 24 March 2008 9:09:36 PM(UTC)
Thats the one.
This page was generated in 1.117 seconds.
