Hi all,
I have made a major boo boo, have a nine inch diff in Ht with Commodore rear disc brakes and stud pattern. Now have gone to purchase and fit Weld Draglites and have been told they don't come in Commodore pattern only Chev(HQ).
I have been told they will fit though it will be tight and may stress the studs, has anyone out there come across this and will it be ok. I do not want to redrill the axles as they have just been made and brought from Moser.
Under NO circumstances even try and fit HQ pattern rims onto commodore pattern axles.
Many people have done it and some of them are dead..!!
The HQ Pattern and Commodore pattern actually look the same but there is about a 1.5mm difference in the stu
You might be lucky here. Commodores had a 12mm stud and HQ's had a 7/16" stud. Fords have a larger 1/2" stud. Maybe your diff place can offset drill the stud holes out to HQ pattern and you can fit bigger Ford studs to the now enlarged holes.
You might be lucky here. Commodores had a 12mm stud and HQs had a 7/16" stud. Fords have a larger 1/2" stud. Maybe your diff place can offset drill the stud holes out to HQ pattern and you can fit bigger Ford studs to the now enlarged holes.
Because you have discs on the back you can get blank rotors so that they can be drilled to any pattern. You can put your old rotors on eBay to recoup some of the costs if they are still usable.
James
You only have to be in front at the end of the race. |
Many
Because you have discs on the back you can get blank rotors so that they can be drilled to any |
where does one buy blank rotors or who re drills axles it sounds like the perfect answer to fit discs to the rear of my hq cheers
I think Jims got the right idea although Im sure moser axles have 1/2" studs already fitted (mine do)
if that wont work, id get the axles flanges drilled, those axles are plenty strong enough to cope with it. Get some blank disc drilled to suit. Any
I think Jim's got the right idea although Im sure moser axles have 1/2" studs already fitted (mine do)
if that wont work, i'd get the axles flanges drilled, those axles are plenty strong enough to cope with it. Get some blank disc drilled to suit. An
Come on there only rims just choose a set that takes the Commodore pattern.
where does one buy blank rear commodore rotors in nsw ?cheers
where can i buy blank rotors in nsw cheers
Try a DBA retailer, they make stock and performance rotors. This is the Rares on line shop. https://rsp-secure.com/rarespares/Or DBA itself. http://www.dba.com.au/2006/default.aspJames -------------------------------------------------------
You don't need blank rear rotors. The Commodore rear rotors fit on HQ stud pattern, as Dr Terry mentioned, they differ by not much. The important part of the setup is that the centre hub hole in the rotor fits very neatly on the centre flange on the axle. |
You dont need blank rear rotors. The Commodore rear rotors fit on HQ stud pattern, as Dr Terry mentioned, they differ by not much. The important part of the setup is that the centre hub hole in the rotor fits very neatly on the centre flange on the axle. |
