#1 Posted : Wednesday, 26 March 2008 6:09:05 PM(UTC)
I have a HQ 308 coupe, which originally would have had a `rat trap` mechanism. (I don`t have it). I want to put in a cable assembly. The cable I can buy new, but I need the pedal and cable mount bracket(above pedal) I also realise I will have to drill a new hole in firewall. Thanks, Peter
HK1837 Online
#2 Posted : Wednesday, 26 March 2008 8:30:29 PM(UTC)
Peter
What you want is a mid HZ onwards or WB V8 clutch pedal and bracket. 6cyl is no good to you as it pivots in a different hole (which HQ doesnt have) and doesnt give you enough clutch fork travel. Its easy to tell if its the right HZ as there will
HK1837 Online
#3 Posted : Wednesday, 26 March 2008 8:30:29 PM(UTC)
Peter
What you want is a mid HZ onwards or WB V8 clutch pedal and bracket. 6cyl is no good to you as it pivots in a different hole (which HQ doesn't have) and doesn't give you enough clutch fork travel. It's easy to tell if it's the right HZ as there w
253tonner Offline
#4 Posted : Thursday, 27 March 2008 2:16:58 AM(UTC)
253tonner
hi i have all you need as i just pull it out of my v8 hz tonner
i have the clutch and brake assembly if this help you i pull it out
becease i put auto i in the tonnerif youwant to you can ring me (07-54267621 ask allen) cheers
old holden rule
v8 are the go who
give's sh## about
fuel
#5 Posted : Thursday, 27 March 2008 8:58:52 AM(UTC)
Thanks for the advise Byron. Allen I will give you a ring tommorow re the parts. Thanks Peter
