bundybluedog Offline
#1 Posted : Thursday, 27 March 2008 9:02:48 PM(UTC)
bundybluedog
I have a shifter and linkage and rattrap out of a 4 speed V8 HQ will this work on the saginaw or muncie gearbox in a HQ?
#2 Posted : Thursday, 27 March 2008 10:07:00 PM(UTC)
It will if you use a factory HT-HG 253/308 Saginaw bellhousing and clutch fork. I'm almost certain it works without mods. However you are much better off with a WB V8 pedal, cable, cable bracket (under dash) and clutch fork and an aftermarket bellhousing
#3 Posted : Thursday, 27 March 2008 10:07:00 PM(UTC)
It will if you use a factory HT-HG 253/308 Saginaw bellhousing and clutch fork. Im almost certain it works without mods. However you are much better off with a WB V8 pedal, cable, cable bracket (under dash) and clutch fork and an aftermarket bellhousing (
JBM Offline
#4 Posted : Thursday, 27 March 2008 10:20:14 PM(UTC)
JBM
A Muncie has reverse to the right and up, which may not work with the shifter you have if it is for an Aussie 4 speed. If its an original HQ 350 Muncie shifter then its a super rare item.
Regards James
#5 Posted : Thursday, 27 March 2008 10:35:34 PM(UTC)
Sorry Bundy, I missed the shifter bit. The Aussie 4spd shifter is useless for a Saginaw or Muncie.
#6 Posted : Thursday, 27 March 2008 10:40:06 PM(UTC)
bundybluedog
can you get after market shifters for them?
JBM Offline
#7 Posted : Thursday, 27 March 2008 10:49:06 PM(UTC)
JBM
I got a Speco Muncie shifter for my Torana but had cut the tunnel. A Hurst Indy shifter fits well but was too close to the passenger seat in the Torana without using a spacer for the gearstick. About 5-6 years ago the Hurst Indy was about 200 and the Spec
Edited by user Thursday, 27 March 2008 10:50:32 PM(UTC)  | Reason: Not specified
#8 Posted : Thursday, 27 March 2008 11:11:10 PM(UTC)
bundybluedog
thanks for that guys.
dan
hkpremier1968 Offline
#9 Posted : Friday, 28 March 2008 2:10:22 AM(UTC)
hkpremier1968
Hi Bundybluedog, I have a Saginaw Hurst shifter and a V gate shifter at home I will not be using on my HK. They where both on a HQ at one stage so if you can not find one I would be happy to sell one to you. Cheers.
Lots of cars, Lots of projects and L
Lots of cars, Lots of projects and Lots of work = No brains, No life and No money!!
#10 Posted : Friday, 28 March 2008 4:47:01 AM(UTC)
bundybluedog
i will drop you an email hkprem
i seen the saginaw and muncie are a dime a dozen in the states are the shifters diferant and whats the best box.
#11 Posted : Friday, 28 March 2008 4:50:39 AM(UTC)
dan you might want to check out just who hkprem is before you fork over any money
http://fastlane.com.au/f...topic.asp?TOPIC_ID=15763
Guest (5)
