basketcasebear Offline
#1 Posted : Saturday, 29 March 2008 5:16:11 AM(UTC)
basketcasebear
hey yall,
i might be needing a late model 308 engine to go in front of my T400.
just wondering which engines will fit?
i know i have read it in here before,,but could not find it again?
thankee
bcb
ptpro
some men see things as they are, and ask "why"
I dream of things that never were, and say, "bloody ripper idea mate, lets try it",!!
DOH!!!
boom Offline
#2 Posted : Saturday, 29 March 2008 5:53:10 AM(UTC)
boom
everything VN onwards.
In cubes we trust.
#3 Posted : Saturday, 29 March 2008 7:36:21 AM(UTC)
Was thanked: 613 time(s) in 580 post(s)
Including GenIII and IV.
#4 Posted : Saturday, 29 March 2008 10:04:02 AM(UTC)
basketcasebear
hey thanks boom byron,,
can these engines run ok with carby?
and are they alloy heads? and if so, how much lighter, ruffly,, are they compared to cast head 308?
bcb
ptpro
DOH!!!
boom Offline
#5 Posted : Saturday, 29 March 2008 10:13:38 AM(UTC)
boom
they are still cast heads(304, not Gen III and IV) not much lighter. They do run o.k with a carby, but you have to get the right manifold. lots of choices though. lowest i've seen is $350 for an edelbrock performer. highest is a harrop single plane - $880
boom Offline
#6 Posted : Saturday, 29 March 2008 10:13:38 AM(UTC)
boom
they are still cast heads(304, not Gen III and IV) not much lighter. They do run o.k with a carby, but you have to get the right manifold. lots of choices though. lowest ive seen is $350 for an edelbrock performer. highest is a harrop single plane - $880.
#7 Posted : Saturday, 29 March 2008 7:08:41 PM(UTC)
As Boom says theyll work fine. The VN on V8 engines are basically identical to the earlier ones, but the heads are different hence the different manifold (and cam and exhaust). All the early stuff still fits them otherwise eg water pump, timing case, dizz
#8 Posted : Saturday, 29 March 2008 7:08:41 PM(UTC)
As Boom says they'll work fine. The VN on V8 engines are basically identical to the earlier ones, but the heads are different hence the different manifold (and cam and exhaust). All the early stuff still fits them otherwise eg water pump, timing case, diz
#9 Posted : Saturday, 29 March 2008 11:25:10 PM(UTC)
basketcasebear
thanks again boom byron,
as i did a conversion, and the 308 i put in, is slightly heavier i think than the diesal that came out??
the van seems a little bit more spongy, for want of a better term,,
as i am a little worried about the motor that went in
DOH!!!
boom Offline
#10 Posted : Saturday, 29 March 2008 11:30:30 PM(UTC)
boom
no changes to the manifold. but if you go straight gas, then bolt the GRA throttlebody to the bananas.
there are alloy heads, but not factory.
In cubes we trust.
#11 Posted : Sunday, 30 March 2008 8:41:04 AM(UTC)
basketcasebear
hey thanks BOOM.!!!
I presume the GRA throttle body, is the bit that is bolted onto the top of the qaud carby??
so are you meaning to wipe the qaud carby? and then bolt the whole gas gizmo straight onto the top of the banana looking manifold?
and if
DOH!!!
boom Offline
#12 Posted : Sunday, 30 March 2008 6:48:10 PM(UTC)
boom
oh, ok you're using a gas hat, sorry i presumed you meant a gas research throttlebody. if you are using a gas hat on top of a quadrajet, then you need a carburettor manifold to suit the heads that are on the engine (Pre Pollution/Pollution/VN-VT).
boom Offline
#13 Posted : Sunday, 30 March 2008 6:48:10 PM(UTC)
boom
oh, ok youre using a gas hat, sorry i presumed you meant a gas research throttlebody. if you are using a gas hat on top of a quadrajet, then you need a carburettor manifold to suit the heads that are on the engine (Pre Pollution/Pollution/VN-VT).
musksell Offline
#14 Posted : Monday, 31 March 2008 6:03:31 AM(UTC)
musksell
Mr Bear,
sometimes you have to think outside the forrest.....
What price do you think gas is going to be in 2 years time....??
Maybe 75 cents.... 85 cents
Put a V6 commodore motor in it .......
15% lighter......that fixes that prob
boom Offline
#15 Posted : Monday, 31 March 2008 6:24:40 AM(UTC)
boom
100% less bragging rights, and 99% less aural pleasure.
In cubes we trust.
musksell Offline
#16 Posted : Monday, 31 March 2008 6:31:27 AM(UTC)
musksell
I wonder Mr Boom....?
#17 Posted : Monday, 31 March 2008 10:11:24 AM(UTC)
well shiver me timbers there,, muskell, i,m still trying to look outside the square,, now you want me to look outside a forest???
no way hosay!!
but you are certainly talking the talk, and probably walking the walk!!
ok lets get serious pro,s an
#18 Posted : Tuesday, 1 April 2008 1:23:11 AM(UTC)
Best bet is the VN 5.0 fitted with a 253/308 dissy. Replace the throttle body with a GRA mixer (as Boom said) OR adapt your gas hat to work with the 304's throttle body. Option 2 should not be that hard.
You will end up with a more powerful engine t
Edited by user Tuesday, 1 April 2008 1:24:34 AM(UTC)  | Reason: Not specified
#19 Posted : Tuesday, 1 April 2008 1:23:11 AM(UTC)
Best bet is the VN 5.0 fitted with a 253/308 dissy. Replace the throttle body with a GRA mixer (as Boom said) OR adapt your gas hat to work with the 304s throttle body. Option 2 should not be that hard.
You will end up with a more powerful engine th
musksell Offline
#20 Posted : Tuesday, 1 April 2008 5:55:34 PM(UTC)
musksell
Thats the point....if youre going fuel injected V8,
youll need different petrol tank then the manifold...cat converter.....in Victoria you might have to get a VASS reort for that....not sure, they cost $700 (appox)....so ring vic roads first.
Its just
Guest (7)
This page was generated in 0.276 seconds.
