Jim140862 Offline
#1 Posted : Wednesday, 2 April 2008 12:34:40 AM(UTC)
Jim140862
Does anybody happen to know the tension (ft/lbs)that I should put on the eight 3/4" headed bolts that go through the rear suspension bushes on the rear trailing arms on a 1975 HJ sedan? Thanks in advance, Jim.
sandman-utes Offline
#2 Posted : Wednesday, 2 April 2008 5:52:57 AM(UTC)
sandman-utes
In the past iv'e just done them up as tight as i can, with a rattle gun ! Hope that helps
Trust me, I've seen this done on TV...
"Experience is a hard teacher because she gives the test first, and the lesson afterwards"
#3 Posted : Wednesday, 2 April 2008 5:52:57 AM(UTC)
sandman-utes
In the past ive just done them up as tight as i can, with a rattle gun ! Hope that helps
Trust me, Ive seen this done on TV...
Jim140862 Offline
#4 Posted : Thursday, 10 April 2008 12:57:14 AM(UTC)
Jim140862
Thanks Sandman. I've found out that the factory spec is 60 ft lbs, so that's what I made them (with the weight of the car sitting down on them). Cheers.
Jim140862 Offline
#5 Posted : Thursday, 10 April 2008 12:57:14 AM(UTC)
Jim140862
Thanks Sandman. Ive found out that the factory spec is 60 ft lbs, so thats what I made them (with the weight of the car sitting down on them). Cheers.
This page was generated in 0.185 seconds.
