#1 Posted : Wednesday, 2 April 2008 5:42:20 AM(UTC)
Hey ive just converted my 186 hk to a worked 307 400hp motor , i upgraded brakes and are soon to get my 9 inch. does anyone know how to go about getting everything engineered. im in adelaide.
is a 9inch engineerable if it is shortened.
also once it is engineered , can my car still be defected by police.
finally how much are you looking at , for full engineering , approx , i know its very pricey. but what like 5 - 10 g
#2 Posted : Wednesday, 2 April 2008 6:26:25 AM(UTC)
There is nothing to Engineer as far as I can tell. HK-HG body shape cane standard with a 350 cubic inch V8. Youve upgraded your brakes. In NSW itd be less than $500 if there was anything to do at all.
___________________________________________________
#3 Posted : Wednesday, 2 April 2008 6:26:25 AM(UTC)
There is nothing to Engineer as far as I can tell. HK-HG body shape cane standard with a 350 cubic inch V8. You've upgraded your brakes. In NSW it'd be less than $500 if there was anything to do at all.
peter_flane Offline
#4 Posted : Wednesday, 2 April 2008 6:46:03 AM(UTC)
peter_flane
Change in rear axle housing requires an engineers report technically. There would be a lot of old Holdens that were optionable with V8's that do not have engineers certificates. Make sure you do go to the registration branch and change your engine number.
peter_flane Offline
#5 Posted : Wednesday, 2 April 2008 6:46:03 AM(UTC)
peter_flane
Change in rear axle housing requires an engineers report technically. There would be a lot of old Holdens that were optionable with V8s that do not have engineers certificates. Make sure you do go to the registration branch and change your engine number.
#6 Posted : Wednesday, 2 April 2008 11:48:36 AM(UTC)
the brakes will need engineering any alteration to brakes does
