Docktor Offline
#1 Posted : Thursday, 3 April 2008 8:35:38 AM(UTC)
Docktor
Hey blokes, Quick question, I can get hold of a 1985 , think they were zk or something offhand ??. 351 fmx and 9 inch... ltd v8. My question,,,,,,, Will the diff bolt into xc and is the power steering units the same , I know the pump will probably be rotary and not piston type but will steering box mount up without mods ?
Doc
Paul351xb Offline
#2 Posted : Thursday, 3 April 2008 9:25:18 AM(UTC)
Paul351xb
I think you will find the diff is set up for a watts link rear end rather than the leaf springs. As for the power steer, the whole set up will bolt straight into the XC without any problems. Same box as XC, better pump.
Docktor Offline
#3 Posted : Friday, 4 April 2008 12:13:28 AM(UTC)
Docktor
Thanks mate, Spose I better climb under for a look at the rear then. Its a bargain, but not if I cant use the 9'er.
Paul351xb Offline
#4 Posted : Friday, 4 April 2008 1:41:37 AM(UTC)
Paul351xb
Shouldn't be a nine incher in the back buddy. Should be a borgy limited slip disc brake set up.
#5 Posted : Saturday, 5 April 2008 3:05:38 AM(UTC)
You could get lucky and actually be looking at a ZJ Fairlane/FC LTD which would have had leaf springs but a Borg Warner diff from factory.
If it is a ZK/FD and a 1985 model (which it probably would not as Ford listed the ZK/FD from 1982-1984) would
Edited by user Saturday, 5 April 2008 3:09:37 AM(UTC)  | Reason: Not specified
#6 Posted : Monday, 7 April 2008 6:02:58 AM(UTC)
Bugger me Jim, I thought I knew some trivail ****, but to know that much about fairlaines/ltd's is amazing. i hit the print button on that and am at work tomorrow so I can drop in and have a good look at it.So you are tellin me if it has a 9 inch hangin o
#7 Posted : Monday, 7 April 2008 6:36:37 AM(UTC)
Well Actually I cheated a bit. I bought a Ford Identification Catalogue off eBay a while ago. The go for $25 (if your lucky) upwards and turn up reasonably often. They cover all model Australian Fords from 1960-1986 XK-XF all Cortinas, Escorts, Capri, La
#8 Posted : Tuesday, 8 April 2008 6:51:25 AM(UTC)
Its a sep 82 car with motor and trans both listed as B. diff certainly not a 9 inch.It is coil spring too btw.... Dont really want it now....
#9 Posted : Tuesday, 8 April 2008 8:08:16 PM(UTC)
Well engine code B = 4.9 NSW high compression and trans code B=3 speed auto floor shift.
Jim...
Some people say I am out of shape but they ar
#10 Posted : Thursday, 10 April 2008 8:32:16 PM(UTC)
3Thanks Jim, But pretty well not worth much to me as far as I am concerned. I 351 block is a couple of hundred bucks and thats about all i want off it. Willing to pass it on to anyone who wants it. The man wants a 1000 bucks for it but like anything proba
