#1 Posted : Saturday, 5 April 2008 2:29:19 AM(UTC)
just quickly has anyone used the High energy header wrap , i was gonna get some as my ignition leads are awfully close ,a long with the fuel lines and shifter cable.
does this stuff work eg. not melt etc.
also ive read people use the high temp paint on the wrap does it not burn off ?
vintageholden Offline
#2 Posted : Saturday, 5 April 2008 4:58:43 AM(UTC)
vintageholden
i used high temp paint and then wrapped in exaust bandage
works well
or if you have the money ceramic coating
#3 Posted : Saturday, 5 April 2008 8:58:58 AM(UTC)
DO NOT USE THIS STUFF!!! this heat wrap keeps the heat in, and doesnt allow it to dissapate, i have seen with my own eyes a set of headers that turned into molten steel when using heat wrap.pacemaker will not warranty these headers if they melt, get them
adam PERTH Offline
#4 Posted : Saturday, 5 April 2008 9:34:40 AM(UTC)
adam PERTH
i use it on my street / strip cars.
The hotter the pipe temp, the faster the exhasust gases will flow which = more HP.
I have never had a drama.
the ones that melted, was the ignition timing spot on?
i have seen pipes glow fron timing too far advanc
