#1 Posted : Monday, 7 April 2008 4:17:05 AM(UTC)
Finally fired up my ute today after 12 months restoration. Runs well but thinking should fit oil pressure and water temp. gauge. Wondering what is best - mechanical or electric. Any advise would be appreciated.
jabba Offline
#2 Posted : Monday, 7 April 2008 6:22:51 PM(UTC)
jabba
Mechanical simpler, but the feeds are a) thicker and b) you end up with a tube full of oil behind the dash. Fine if it all hangs together and you don't move them. Not so fine if something rubs / breaks or you need to remove.
Electric you are just feedi
jabba Offline
#3 Posted : Monday, 7 April 2008 6:22:51 PM(UTC)
jabba
Mechanical simpler, but the feeds are a) thicker and b) you end up with a tube full of oil behind the dash. Fine if it all hangs together and you dont move them. Not so fine if something rubs / breaks or you need to remove.
Electric you are just feedin
#4 Posted : Tuesday, 8 April 2008 5:27:44 AM(UTC)
much appreciated
This page was generated in 0.215 seconds.
