#1 Posted : Saturday, 12 April 2008 3:45:17 AM(UTC)
Hi,K0708 in small numbers after engine number.Is this the date stamp, if so is it 07-10-68.thanks in advance.Cheers Bazza.
#2 Posted : Saturday, 12 April 2008 3:55:43 AM(UTC)
K means McKinnon assembly plant, Canada. 08 is 8th. 07 is July. So this is probably 8/7/68. Check the casting date on the side of the block for the year.
If we all had the same (good) taste, who
#3 Posted : Saturday, 12 April 2008 4:12:47 AM(UTC)
Byron. Was the engine numbers stamped at the assemble plant. E bay inlet manifold j167 , what date is it. Thanks Bazza.
#4 Posted : Saturday, 12 April 2008 6:16:57 AM(UTC)
The K0708 bit was stamped in Canada. the 307xxxxx bit was stamped by the Holden vehicle assembly plant.
J167 on an inlet is 16/11/67.
If we all had the same (good) taste, who would buy all the F
