OK, I'm trying to help out a neighbour who has a VR V8 auto.
The initial problem was the car kept stalling. He gets it home and now when you start it, it idles then when you touch the accelerator it stalls, when you go to restart, it kind of like back fires then stinks of fuel and won't start.
He has replaced the fuel pump as he thought that was the initial problem, still the same.
Any ideas folks would be great.
Thanks.
Get a manual and chck the ECU for fault code.
Dont look at it as being a problem look at it as being a challenge.
Don't look at it as being a problem look at it as being a challenge.
The ALDL plug is under the dash next to steering column. Looking at the 16 pin plug,the top row has 8 pins with #1 starting on the left,bridge out pins 5 and 6 with the ignition in the "ON" position and note the CEL(check engine light)flashing on the das
No worries guys thanks for your help.
I found this as well, so he can work it out for himself, as I told him once upon a time a screw driver and a pair of pliers would get anything started thats worth starting. Haha.
ECU (Engine Control Unit) Fault Codes VR Commodore V8 1994 - 1996
Oh man, Looking at all that above, give me a Carby engine any day. Have they got a code to make the thing go? LOL Edited by user Sunday, 13 April 2008 9:41:15 AM(UTC)
| Reason: Not specified
Thats it!!
The only code missing is....
Code 84 - get out and push!
yep thats what i did, custom,, threw the computer out, better for the wallet, better for stress, better for the enviroment. better economy? if one works out all the real factors.. cheers bcb
ptpro some men see things as they are, an |
more than basketcase than a bear! DOH!!! |
i got the code 67 on my vs v6 can you help me its got something to do with tcc but i dont think the car has got it there is no buttons for it
Hi Jamie.
TCC = Torque Converter Clutch. All V6 automatic Commodores have these.
You might have been thinking about TCS, which is Traction Control System.
Dr Terry |
C85=RAA Roadside assist (lol).sorry only joking,i hate car computers for engine management systems in general, only because i dont understand them. |
Jim in Adelaide.. |
