Fred Offline
#1 Posted : Sunday, 13 April 2008 7:09:19 AM(UTC)
Fred
Just wondering if low profile tyres can be fitted to steel rims.
stevo280472 Offline
#2 Posted : Sunday, 13 April 2008 9:05:52 AM(UTC)
stevo280472
Yes
Go the Dragons!
Go the Dragons!
HOLD ON Offline
#3 Posted : Sunday, 13 April 2008 11:43:49 AM(UTC)
HOLD ON
of course
vintageholden Offline
#4 Posted : Sunday, 13 April 2008 11:44:52 AM(UTC)
vintageholden
i have 10" steel rims with 295x50x15
Fred Offline
#5 Posted : Sunday, 27 April 2008 10:59:01 PM(UTC)
Fred
Are the Dragons a basketball team.
stevo280472 Offline
#6 Posted : Monday, 28 April 2008 1:48:54 AM(UTC)
stevo280472
Yes they are, but in this case it means the St George Ilawarra Dragons rugby league team.
Go the Dragons!
Go the Dragons!
bluHJ Offline
#7 Posted : Monday, 28 April 2008 2:41:08 AM(UTC)
bluHJ
Just remember that your speedo could be out. Use the link below to calculate how far.
http://www.miata.net/garage/tirecalcold.html
cheers...bluHJ
basketcasebear Offline
#8 Posted : Monday, 28 April 2008 5:43:55 AM(UTC)
basketcasebear
Hey blu HJ,
i used your tyre site, it was good, but with my van, it is slightly diferent,? i have a 308 t400, 3.35 diff with 235mm x 75, 15inch wheels and tyres?
so i am wondering how one works out the speed?
bcb
ptpro
some men see things
DOH!!!
bluHJ Offline
#9 Posted : Monday, 28 April 2008 6:47:56 AM(UTC)
bluHJ
bcb
The only thing I can think of is find out what tyres you should have. Then work out if you have the right drive and driven gear. Use the link below to a photobucket picture. Then you should be ok. You might have a bit of trouble with such a
bluHJ Offline
#10 Posted : Monday, 28 April 2008 6:49:39 AM(UTC)
bluHJ
Oops. Sorry. Link to the carsale site doesnt work. Check on Fastlane in cars for sale.
Cheap plug.
bluHJ Offline
#11 Posted : Monday, 28 April 2008 6:49:39 AM(UTC)
bluHJ
Oops. Sorry. Link to the carsale site doesn't work. Check on Fastlane in cars for sale.
Cheap plug.
#12 Posted : Tuesday, 29 April 2008 4:14:00 AM(UTC)
basketcasebear
yes bluhq,,thanks fer that,
it is probably quite simple??
all i need to know is>>> what revolutions are happening in a 308 t400 with a 3.35 diff,, with normal 14inch wheels, and what speed that is??
because i dont have an existing car to ref
DOH!!!
musksell Offline
#13 Posted : Tuesday, 29 April 2008 6:38:52 AM(UTC)
musksell
I check my speedo on the big speed check 30kms out of Melbourne on the hume, and checke dit again when dyno tested to get the best out of gas system.You could get just the bear essential tune...
turbo 400 in top gear is one to one I would say.So 335 diff
#14 Posted : Tuesday, 29 April 2008 7:46:43 AM(UTC)
basketcasebear
yes yes yes,,,thanks muskell..
if your wheels are 14inch, with 205,65 tyres, then mine will end up giving me 17% less revs, according to that tyre speed wheel change site?
so hopefully, i will be at 2300>2400 revs at 100klms??
and i am hoping with w
Edited by user Tuesday, 29 April 2008 7:50:56 AM(UTC)  | Reason: Not specified
DOH!!!
#15 Posted : Tuesday, 29 April 2008 8:06:10 AM(UTC)
hi bear, alas, I have to say I do not know the answer to your question, or, indeed, the question to your answer. However, I am looking forward to your beast giving you many miles of motoring pleasure, regardless of the RPM or mileage it returns. All I can
jabba Offline
#16 Posted : Tuesday, 29 April 2008 5:28:01 PM(UTC)
jabba
About the only part of the whole equation which is unable to be calculated is the number of revolutions of the speedo drive cable per kilometer. This information is next to impossible to find (I certainly haven't for my HJ).
From your tire / wheel / d
jabba Offline
#17 Posted : Tuesday, 29 April 2008 5:28:01 PM(UTC)
jabba
About the only part of the whole equation which is unable to be calculated is the number of revolutions of the speedo drive cable per kilometer. This information is next to impossible to find (I certainly havent for my HJ).
From your tire / wheel / di
#18 Posted : Wednesday, 30 April 2008 10:00:35 PM(UTC)
basketcasebear
hey jabba,,
i wil be having a electronic speedo, so i dont need to know about speedo cable teeth,
all i was trying to do was figure out what revs i would be doing, with the 3.35 diff, and the 235 15inch,x 75 tyres? at 100 klms,
the best i can figure o
DOH!!!
jabba Offline
#19 Posted : Friday, 2 May 2008 4:47:08 PM(UTC)
jabba
Working the math, you should end up with approximately 2500 RPM when doing 100Kph with the combination quoted. Based on the gearbox top ratio being 1:1 (which most are). Any overdrive will adjust this figure accordingly.
This is based on the circumfere
#20 Posted : Friday, 2 May 2008 7:49:10 PM(UTC)
basketcasebear
hey thanks jabba,
here hoping that the 308 will be about right, for power needs??
the camper is only rated at 1460kilograms, Tare,,
and with the add ons, and take off,s i m hoping its weight with everythang in it, will be about 1550>1600kilo,s
and
DOH!!!
This page was generated in 0.134 seconds.
