Thanks for the info guys
My Monaros: - HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim - HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
quote: Originally posted by Mr.Jones
Just to confuse things more didnt HSV have a 'red' (sv5000)and 'black' (vn gpa & vp gts)
Just to confuse things more didnt HSV have a red (sv5000)and black (vn gpa & vp gts) moto
WHAT MODEL ARE THESE OFF? CASTING NUMBER 92027335
92027335 are regular VL V8 ULP heads.
A lot of people aim to achieve nothing in life - and have amazing accuracy. |
THANKS MICK JUST WANTED TO KNOW BECAUSE I BOUGHT SOME WITH L34 VALVES AND LS1 SPRINGS WASNT SURE IF X POLICE OR WHAT? NITRATED SEATS ETC
Stock VL heads have the big valves in them, and nitrided seats - best of both worlds.
The ports aren't as big as B-cast heads, but this can actually be an advantage, as the airspeed stays higher.
Mick ____________________________________ |
The ports arent as big as B-cast heads, but this can actually be an advantage, as the airspeed stays higher.
Mick _____________________________________ |
what are B heads ?
i bought a pair the other day for my stroker project. they are complete with the reconditioners lead seal on the ends. the exhaust ports seem to be ground out a little on the top side
yes sonny, its an HQ ute |
yes sonny, it's an HQ ute |
what are B heads ?
i bought a pair the other day for my stroker project. they are complete with the reconditioner's lead seal on the ends. the exhaust ports seem to be ground out a little on the top side
B-cast heads are the L34 type heads that suit blue & black 308/304 carby motors, and were fitted to Brocks. They have the L34 size valves, and larger ports cast into them.
Mick ______________________________________________________________ |
hi, just bought another 308, popped 1 head off to check condition of bores
the head casting is 7449033, i.e. early 308, but the valves appear the same size as the ones in my "B" set of heads
so have they been worked or did they come out with large v |
Hi tenticles
Yes, 7449033 is the casting number for HT/HG 253/308 heads, but larger valves may have been fitted. This has been a very common modification during the 70s, 80s & 90s.
Just remove a pair of valves & measure the diameter of the valves' h |
Hi tenticles
Just remove a pair of valves & measure the diameter of the valves he |
thanx dr
a quick measure shows the small inlet is 44 mm and the early heads and "B" heads are about 49mm
but i couldn't pull a valve to get a more accurate dimension
thanx dr
but i couldnt pull a valve to get a more accurate dimension
Thats close enough tenticles - the B-cast heads run 2.02 inch inlets, which is 51.3mm, and I dare say not many people could get any closer than 49mm with the valve still in the head.
Id guess the 44mm ones are somewhere around 1.75"
That's close enough tenticles - the B-cast heads run 2.02 inch inlets, which is 51.3mm, and I dare say not many people could get any closer than 49mm with the valve still in the head.
I'd guess the 44mm ones are somewhere around 1.75"
Mic |
