2 Pages<12
monaro mark Offline
#21 Posted : Saturday, 19 April 2008 5:20:23 AM(UTC)
monaro mark
Thanks for the info guys
My Monaros:
- HQ GTS 4 Monaro 350, Auto, Mustard, Black Trim
- HQ GTS 4 Monaro 308, Manual, Orchid Metallic, Black Trim
boom Offline
#22 Posted : Sunday, 20 April 2008 2:29:15 AM(UTC)
boom
Originally posted by Mr.Jones
Just to confuse things more didnt HSV have a 'red' (sv5000)and 'black' (vn gpa & vp gts)
boom Offline
#23 Posted : Sunday, 20 April 2008 2:29:15 AM(UTC)
boom
Just to confuse things more didnt HSV have a red (sv5000)and black (vn gpa & vp gts) moto
#24 Posted : Tuesday, 10 June 2008 5:21:25 AM(UTC)
WHAT MODEL ARE THESE OFF? CASTING NUMBER 92027335
#25 Posted : Tuesday, 10 June 2008 5:23:55 AM(UTC)
#26 Posted : Tuesday, 10 June 2008 5:37:38 AM(UTC)
92027335 are regular VL V8 ULP heads.
#27 Posted : Tuesday, 10 June 2008 5:45:43 AM(UTC)
THANKS MICK JUST WANTED TO KNOW BECAUSE I BOUGHT SOME WITH L34 VALVES AND LS1 SPRINGS WASNT SURE IF X POLICE OR WHAT? NITRATED SEATS ETC
#28 Posted : Tuesday, 10 June 2008 5:59:14 AM(UTC)
Stock VL heads have the big valves in them, and nitrided seats - best of both worlds.
The ports aren't as big as B-cast heads, but this can actually be an advantage, as the airspeed stays higher.
____________________________________
#29 Posted : Tuesday, 10 June 2008 5:59:14 AM(UTC)
The ports arent as big as B-cast heads, but this can actually be an advantage, as the airspeed stays higher.
_____________________________________
tenticles Offline
#30 Posted : Tuesday, 10 June 2008 5:25:28 PM(UTC)
tenticles
what are B heads ?
i bought a pair the other day for my stroker project. they are complete with the reconditioners lead seal on the ends. the exhaust ports seem to be ground out a little on the top side
yes sonny, its an HQ ute
yes sonny, it's an HQ ute
tenticles Offline
#31 Posted : Tuesday, 10 June 2008 5:25:28 PM(UTC)
tenticles
what are B heads ?
i bought a pair the other day for my stroker project. they are complete with the reconditioner's lead seal on the ends. the exhaust ports seem to be ground out a little on the top side
#32 Posted : Tuesday, 10 June 2008 7:49:45 PM(UTC)
B-cast heads are the L34 type heads that suit blue & black 308/304 carby motors, and were fitted to Brocks.
They have the L34 size valves, and larger ports cast into them.
______________________________________________________________
tenticles Offline
#33 Posted : Monday, 23 June 2008 5:27:02 PM(UTC)
tenticles
hi, just bought another 308, popped 1 head off to check condition of bores
the head casting is 7449033, i.e. early 308, but the valves appear the same size as the ones in my "B" set of heads
so have they been worked or did they come out with large v
#34 Posted : Monday, 23 June 2008 5:50:58 PM(UTC)
Was thanked: 219 time(s) in 199 post(s)
Hi tenticles
Yes, 7449033 is the casting number for HT/HG 253/308 heads, but larger valves may have been fitted. This has been a very common modification during the 70s, 80s & 90s.
Just remove a pair of valves & measure the diameter of the valves' h
#35 Posted : Monday, 23 June 2008 5:50:58 PM(UTC)
Hi tenticles
Just remove a pair of valves & measure the diameter of the valves he
tenticles Offline
#36 Posted : Tuesday, 24 June 2008 3:03:58 PM(UTC)
tenticles
thanx dr
a quick measure shows the small inlet is 44 mm and the early heads and "B" heads are about 49mm
but i couldn't pull a valve to get a more accurate dimension
tenticles Offline
#37 Posted : Tuesday, 24 June 2008 3:03:58 PM(UTC)
tenticles
thanx dr
but i couldnt pull a valve to get a more accurate dimension
#38 Posted : Tuesday, 24 June 2008 4:35:53 PM(UTC)
Thats close enough tenticles - the B-cast heads run 2.02 inch inlets, which is 51.3mm, and I dare say not many people could get any closer than 49mm with the valve still in the head.
Id guess the 44mm ones are somewhere around 1.75"
#39 Posted : Tuesday, 24 June 2008 4:35:53 PM(UTC)
That's close enough tenticles - the B-cast heads run 2.02 inch inlets, which is 51.3mm, and I dare say not many people could get any closer than 49mm with the valve still in the head.
I'd guess the 44mm ones are somewhere around 1.75"
Mic
2 Pages<12
