#1 Posted : Wednesday, 16 April 2008 10:24:49 PM(UTC)
Want to move away from (unfortunately Australian) high temperature nylon fuel filters as tailings of nylon must have been left in the output side of the fuel filter during manufacture and lodged under the valves of the fuel pump causing the pump to cease functing. Pressure is 5 to 6 PSI in the fuel line.
Need a fuel filter which has been manufactured to much higher standard. What can be used that is of superior quality ??
#2 Posted : Saturday, 3 May 2008 6:56:48 PM(UTC)
Use a Z200 efi fuel filter. They are finer in the filter medium and fit straight into the fuel line
This page was generated in 0.088 seconds.
