#1 Posted : Thursday, 17 April 2008 3:22:50 AM(UTC)
Hi has anyone got the list of diagnosis codes for the WH with a supercharged V6 & which pins on the plug to bridge? is it same as VS??.
The cars idling like a pig on start up but then comes good after about 2 mins? any idea's would be greatful.
thank's
kevin
mmazz30 Offline
#2 Posted : Thursday, 17 April 2008 6:56:20 AM(UTC)
mmazz30
http://justcommodores.co...cles/vs_computer_v6.php
I think it was pins 5 and 6.
Top row with pin 1 starting top left
Cant remember if the SC had different codes.
#3 Posted : Friday, 18 April 2008 3:40:53 AM(UTC)
thank's but still no help.. I also need the location of the data plug & which pins to short out, I have found a full list of codes for the VT so should be basically the same.
#4 Posted : Friday, 18 April 2008 3:40:53 AM(UTC)
thanks but still no help.. I also need the location of the data plug & which pins to short out, I have found a full list of codes for the VT so should be basically the same.
mmazz30 Offline
#5 Posted : Friday, 18 April 2008 8:02:31 AM(UTC)
mmazz30
Under the steering column.....as i said pins 5 and 6
#6 Posted : Saturday, 19 April 2008 5:00:34 AM(UTC)
No plug there to be found, only a fuse panel & the loom running upto the steering wheel controls...
#7 Posted : Saturday, 19 April 2008 9:19:22 PM(UTC)
Get on your back and have another look mmazz30 is right
#8 Posted : Sunday, 20 April 2008 3:15:08 AM(UTC)
yes I wasnt looking in the right place, I was looking behind the lower dash panel. der!!
#9 Posted : Sunday, 20 April 2008 3:15:08 AM(UTC)
yes I wasn't looking in the right place, I was looking behind the lower dash panel. der!!
