#1 Posted : Sunday, 20 April 2008 9:13:41 AM(UTC)
ok heres 1 for u guys i have a fresh 351 bottom end its 30 thou over blah blah it runs on straght gas but i think the valves are now bent (due to a small stuff up with the cam) just wondering if i put 302 closed chamber heads on what problems will i have due to the comp been higher any help is appeciated thanks
#2 Posted : Sunday, 20 April 2008 9:42:25 AM(UTC)
G'day Rob,
I think you will have to actually check what your true volumes are as it sounds like your motor has had some work done.
But remember LPG will run higher compression ratios than petrol.
I'm building a 393C running 11:1 on straight gas.
Hop
