#1 Posted : Monday, 21 April 2008 8:01:23 PM(UTC)
Can anyone tell me If any 13 inch rims out there fit straight on to my 1951 fx ute. It has it's original stud pattern with 15 inch rims at the moment. I've heard LJ torana rims fit but want to hear it fro someone who's done it.
JBM Offline
#2 Posted : Monday, 21 April 2008 8:30:52 PM(UTC)
JBM
All rims from 48-215 to HG and Torana except L34 and A9X have the same stud pattern.
The PCD is 4.25" or just under 108 mm.
James
edi
Edited by user Monday, 21 April 2008 8:39:11 PM(UTC)  | Reason: Not specified
#3 Posted : Monday, 21 April 2008 8:41:44 PM(UTC)
Wrong info - 48-55 have different Stud patterm - I have a single" rim to suit but once you stick the hub cap on it is nearly impossible to get it off again!!
#4 Posted : Monday, 21 April 2008 10:46:17 PM(UTC)
well Im after some with the same PCD and an offset that fits a fx ?
#5 Posted : Monday, 21 April 2008 10:46:17 PM(UTC)
well I'm after some with the same PCD and an offset that fits a fx ?
JBM Offline
#6 Posted : Monday, 21 April 2008 11:20:56 PM(UTC)
JBM
I found this post on oldholden.com and it appears that FX-J had their own stud pattern on 15" rims. The rest up to HQ and most Toranas have the same pattern with different wheel diameters. Im not sure what the hub cap reference above is??
This link has
vintageholden Offline
#7 Posted : Monday, 21 April 2008 11:32:16 PM(UTC)
vintageholden
yes fx are different.....hard to find as well
#8 Posted : Tuesday, 22 April 2008 2:43:09 AM(UTC)
fj had the same patern as early landrovers oao
#9 Posted : Tuesday, 22 April 2008 3:33:15 AM(UTC)
when changing FJ to 13" wheels we used to replace axles/drums , front hubs, brakes etc with FE to EK
adam PERTH Offline
#10 Posted : Tuesday, 22 April 2008 3:37:14 AM(UTC)
adam PERTH
Why not run with the original 15" widened to 6" with the original hubcaps?
#11 Posted : Tuesday, 22 April 2008 5:45:03 AM(UTC)
thanks everyone ill keep thinking about it! Im intrested in lowering her a bit and thought 13 inch rims would drop it down enough without wrecking my front end.
#12 Posted : Tuesday, 22 April 2008 5:45:03 AM(UTC)
thanks everyone i'll keep thinking about it! I'm intrested in lowering her a bit and thought 13 inch rims would drop it down enough without wrecking my front end.
Rod32320 Offline
#13 Posted : Wednesday, 23 April 2008 3:12:01 AM(UTC)
Rod32320
Go the EK hb and brake route. Its an easy fix and you get a minor brake upgrade in the process. EK brake drums are a lot easier to get off too. FC to HR rear end will also fit with no mods. If you want to run a booster CRS have a kit to fit Torana discs t
#14 Posted : Wednesday, 23 April 2008 3:40:50 AM(UTC)
thanks rod, I'll check out CRS's website.
#15 Posted : Wednesday, 23 April 2008 3:40:50 AM(UTC)
thanks rod, Ill check out CRSs website.
Guest (10)
This page was generated in 0.341 seconds.
