adam PERTH Offline
#1 Posted : Tuesday, 22 April 2008 2:36:17 AM(UTC)
adam PERTH
WHen did it change from 5.0(130) to 4.75 (120)
was it around 1966?
#2 Posted : Tuesday, 22 April 2008 3:01:39 AM(UTC)
Not sure what you mean.
Note that 4.75" isn't 120mm either. It's 120.65mm. This is the reason why you can't put HQ wheels (4.75") on Commodore (120mm) and vice versa.
If we all had the same (g
#3 Posted : Tuesday, 22 April 2008 3:01:39 AM(UTC)
Note that 4.75" isnt 120mm either. Its 120.65mm. This is the reason why you cant put HQ wheels (4.75") on Commodore (120mm) and vice versa.
If we all had the same (good
adam PERTH Offline
#4 Posted : Tuesday, 22 April 2008 3:24:34 AM(UTC)
adam PERTH
the Early US built GM have a larger PCD, around 130 or 5.0 when from and until, i am unsure.
what did the C20 / C30 run up front???
I apologise for not inc decimal point of HQ size.
I guess Technically, 120.65 should be rounded up to 121.
He who h
Edited by user Tuesday, 22 April 2008 3:35:52 AM(UTC)  | Reason: Not specified
#5 Posted : Tuesday, 22 April 2008 3:46:22 AM(UTC)
Hi Guys.
Chev have had the 4.75" (120.65mm) PCD pattern since before 1953, not sure how much before that.
However, Buick Oldsmobile, Cadillac & some Pontaic models used 5.00" (127mm) PCD well after that (at least into the late 1970s).
adam PERTH Offline
#6 Posted : Tuesday, 22 April 2008 3:56:06 AM(UTC)
adam PERTH
thanks terry.
Do you know about the C20 / C30?
Edited by user Tuesday, 22 April 2008 3:59:06 AM(UTC)  | Reason: Not specified
#7 Posted : Tuesday, 22 April 2008 7:05:18 AM(UTC)
From memory the C30 is an 8 stud. My Overlander had a Dana60 rear diff which had a 6 stud pattern the same as a Landcruiser/Patrol but the Chevs with the same diffs were 8 stud. Although I think some of the C20 and K20 Chevs had 6 stud 5.5" like Landcruis
Guest (7)
