rb30EJvan Offline
#1 Posted : Tuesday, 22 April 2008 7:06:05 AM(UTC)
rb30EJvan
has anyone fitted a CRS front mount rack HR front to a EH if so what steering colum did you use???????
The Yeti Offline
#2 Posted : Tuesday, 22 April 2008 4:20:20 PM(UTC)
The Yeti
when I did the EJ with the RB 30 I just used the STD box with HR drag link there wasnt much clearance with the CRS sump but htere was clearance none the less
As for the CRS rack why not go to the CRS forum? From memory most guys use a torana column bu
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Custom Offline
#3 Posted : Tuesday, 22 April 2008 5:54:17 PM(UTC)
Custom
If you are going to fit a rack and pinion front end use either one of these www.rodsracks.com.au or www.v6conversions.com.au Talk to anyone with a CRS front rack front end and theyll tell what they do.
If you can get away with it fit a reco steering bo
Custom Offline
#4 Posted : Tuesday, 22 April 2008 5:54:17 PM(UTC)
Custom
If you are going to fit a rack and pinion front end use either one of these www.rodsracks.com.au or www.v6conversions.com.au Talk to anyone with a CRS front rack front end and they'll tell what they do.
