#1 Posted : Tuesday, 22 April 2008 7:02:36 PM(UTC)
Hey all.
I own a 1999 VT Calais, when it rains I end up with a lot of water at my feet under the carpet (drivers side). I recently had the windscreen replaced which didn't help. Can anyone tell me where it may be coming in? Im thinking it may be a common problem...
Mick.
mmazz30 Offline
#2 Posted : Wednesday, 23 April 2008 6:34:37 AM(UTC)
mmazz30
Hi Mick im not 100% sure but i think the problem was with the door seals on the body side not on the door itself and was fixed on the VX from memory.
Check out Justcommodores.com.au for VT faults
Cheers...mario
mmazz30 Offline
#3 Posted : Wednesday, 23 April 2008 6:34:37 AM(UTC)
mmazz30
Hi Mick i'm not 100% sure but i think the problem was with the door seals on the body side not on the door itself and was fixed on the VX from memory.
Cheers...mario
#4 Posted : Wednesday, 23 April 2008 4:14:30 PM(UTC)
sit in the car and get someone to squirt it with a hose and see if you can trace it. some earlier cars had leaks around the firewall area where the bonnet hinge goes under the plenum, put the hose under there too.
#5 Posted : Friday, 25 April 2008 1:21:23 AM(UTC)
Thanks guys. Really appreciate the help.
Mick.
