_DV8 Offline
#1 Posted : Friday, 25 April 2008 1:15:51 AM(UTC)
_DV8
Just wondering if anyone knows if a 302 dizzy is the same as a 351 dizzy?
Paul351xb Offline
#2 Posted : Friday, 25 April 2008 2:10:26 AM(UTC)
Paul351xb
Yes but there are a couple of different types of dizzies for the clevelands. What year motor are you using and what year motor is the other dizzy coming out of?
_DV8 Offline
#3 Posted : Friday, 25 April 2008 9:45:02 AM(UTC)
_DV8
I have a 1978 clevo electronic ignition is it campatable with a 302
Paul351xb Offline
#4 Posted : Wednesday, 30 April 2008 3:43:29 AM(UTC)
Paul351xb
What's the 302 out of? If it's XC or earlier than yes. Just make sure the wire to the module isn't cut or spliced. Pretty sure you will need to mod the voltage wire.
sly376 Offline
#5 Posted : Wednesday, 28 May 2008 6:35:39 AM(UTC)
sly376
some early models had points ignition, xc 351 engines came out with electronic ignition & external module, the later models like XD XE had the module on the side of the dizzy plus the shaft is different on the black motors.
Irish Pete Offline
#6 Posted : Wednesday, 28 May 2008 7:37:57 AM(UTC)
Irish Pete
I think there is some difference in the shaft length of the dizzy, depending on whether its an early or late block clevo(or so I have been told)
Peter.
"If It doesn't fit, use a bigger hammer!"
Peter.
<i>"If It doesn't fit, use a bigger hammer!"</i>
#7 Posted : Sunday, 22 June 2008 1:59:50 PM(UTC)
G day Irish Pete yes there is a difference in the dizzy shaft ,not length but width 8th of a thou.only xd xe were made in aus.
This page was generated in 0.103 seconds.
