pdtphil Offline
#1 Posted : Thursday, 1 May 2008 3:41:00 AM(UTC)
pdtphil
Hi all, a friend has a WB Statesman and the problem is that it keeps snapping the lowest bolt in the Power Steering Box. Is this a common problem or can it suggest a more serious problem (Chassis cracked etc). Cheers Phil.G
"If in doubt, Power out"
#2 Posted : Saturday, 3 May 2008 9:02:39 PM(UTC)
im no expert but it does suggest to me ..cracked or bent chassis ,but does it wheel align properly? also check alignment from front to back wheels ,accident damage?,failing that get grade"8" bolts if you can,see if that helps? maybe even use shims in betw
