hi, just wondering how good a low restriction 2 into 1 system would be using the stock exhaust manifolds
i like the stock appearance, and it would let me continue using the steering column auto selector
as indicated in my trimatic post, i'm after mid range torque, not balls-out top end
yes sonny, it's an HQ ute |
You wont get a huge improvement just changing the pipes as the stock manifolds arent very efficient at exhaust scavenging. For performance some people recommend a bigger single system but I prefer the sound of the twin pipes coming out both sides.
For |
You only have to be in front at the end of the race. |
You have been a member since:: 2/09/2015(UTC) Posts: 43,977
The main thing is that it is low restriction. Putting on extractors will do nothing, if the rest of the system is restricted. I have driven worked 308's with manifolds, that got a wriggle on. good extractors will make it a first class job.
The main thing is that it is low restriction. Putting on extractors will do nothing, if the rest of the system is restricted. I have driven worked 308s with manifolds, that got a wriggle on. good extractors will make it a first class job.
