YetAnotherForum.NET Help
78XC Offline
#1 Posted : Saturday, 10 May 2008 8:03:25 AM(UTC)
78XC
One being 2v and the other 4v doesn't relate to valves per cylinder does it? What do they actually refer to?????
snappa Offline
#2 Posted : Saturday, 10 May 2008 7:51:08 PM(UTC)
snappa
4v have large ports
351 ZH
351 ZH
78XC Offline
#3 Posted : Sunday, 11 May 2008 3:15:19 AM(UTC)
78XC
so if you were to port a 2v head to the same ports it should be the same?
www.earlyfalcons.com Offline
#4 Posted : Sunday, 11 May 2008 3:51:05 AM(UTC)
4 valves per cylinder and 2 valves per cylinder
snappa Offline
#5 Posted : Sunday, 11 May 2008 7:26:37 AM(UTC)
snappa
unless you are goin to build a engine of 500 horsepower or more 4v heads are the go, thats why they are putting stainless tongues into 4v intake ports to improve the flow because they are to big for a street engine to perform properly I am told. 4v intake
351 ZH
#6 Posted : Sunday, 11 May 2008 8:32:06 AM(UTC)
must have been tired when I posted the last one, check out:
http://www.performancefo...ndex.php/t-67134999.html
snappa Offline
#7 Posted : Sunday, 11 May 2008 6:52:49 PM(UTC)
snappa
Yea mate , my 351 was a 4v on vehicle id but that only meant it was a 4 venturi carb.
351 ZH
351 ZH
78XC Offline
#8 Posted : Monday, 12 May 2008 7:40:11 AM(UTC)
78XC
thanks guys I've got at 2v heads now not sure whether i just work them or go 4v I'm just going to have a mild streeter.
#9 Posted : Monday, 12 May 2008 11:13:08 PM(UTC)
2V is the best way to go unless you are pulling very high consistent revs on a track. If you want to change heads these days, Ali is the only way to go. 4V heads are really out dated in design, and if your car is just a streeter, 2V or alloy heads will gi
snappa Offline
#10 Posted : Tuesday, 13 May 2008 2:49:43 AM(UTC)
snappa
2v reco heads to suit unleaded, port n polish, good set valve springs. Get a quote on price and compare with set alloy heads, take it from there
351 ZH
351 ZH
78XC Offline
#11 Posted : Tuesday, 13 May 2008 7:34:47 PM(UTC)
78XC
Cool thats a great idea I think the heads were done for unleaded cause the guy that I bought the motor off said that it was done for LPG and the valves might of been done. Now I just have to find out do the valves look different if I pull the heads off.
#12 Posted : Wednesday, 14 May 2008 12:22:52 AM(UTC)
The heads should be alright if they are to suit LPG, should have hardened seats, inserts for the valve guides and possibly something like stellite valves from memory. I do not think you would be able to identify these items, would probably be a machine sh
78XC Offline
#13 Posted : Thursday, 15 May 2008 4:53:49 AM(UTC)
78XC
I think I'll just drive it for now and until I'm ready to work the heads or until something happens to the valves. then I have to look at everything all you guys have said tlike pricing alloy heads or just working these or getting 4v heads I dont know. I
#14 Posted : Thursday, 15 May 2008 4:58:14 PM(UTC)
My understanding: 2V heads means its fitted with a 2 Venturi manifold - head, and same with 4V heads. In early models, the intake manifold was casted part of the head, so could only be fitted with the orig venturi carb. to upgrade to a 2V head means u
#15 Posted : Saturday, 17 May 2008 6:12:52 AM(UTC)
anyway so far I've got the 2v heads and an edelbrock performer manifold and 650 holley to go on. well see how they go
sly376 Offline
#16 Posted : Sunday, 25 May 2008 2:24:40 AM(UTC)
sly376
4v heads have bigger inlet & exhaust ports, also have bigger valves(exhaust ports are too big). I have ported 302 2V heads on mine & that's the way to go as they have the closed chamber design which raises the compression ratio. A stock 2v head won't flow
Paul351xb Offline
#17 Posted : Sunday, 25 May 2008 6:31:48 AM(UTC)
Paul351xb
One thing that confuses a lot of people in regards to 2V and 4V with the clevo engines that on the XCs with the clevos they have 4V on the compliance plate. In this case it means 4 venturis, or to put it in simpler terms, a 4 barrel thermoquad carby. Th
78XC Offline
#18 Posted : Monday, 26 May 2008 6:37:19 AM(UTC)
78XC
Guys thanks so much for that I think that now i will price up porting the 2v heads and new alloy heads and go that route just have to work out a good street cam to go with my edelbrock performer and 650 holly. thanks again this really helped
sly376 Offline
#19 Posted : Wednesday, 28 May 2008 6:12:46 AM(UTC)
sly376
I found crane F238 cam shaft to be very good that's what i'm running in mine, makes good power & torque from about 2800rpm to 6000rpm, not overly lumpy, very good street cam but it is a solid cam so you would need screw in studs, guide plates, solid lifte
78XC Offline
#20 Posted : Wednesday, 28 May 2008 7:48:46 AM(UTC)
78XC
does that mean with solid cam it becomes something you have to maintain. if you leave it hydraulic is that ok?
Guest (7)
This page was generated in 0.178 seconds.
