XFDAZA Offline
#1 Posted : Tuesday, 13 May 2008 3:55:32 AM(UTC)
XFDAZA
Dose the alloy head on a leaded carbureted XF have welch/welsh plugs in it? If so where are they located?
XFDAZA
#2 Posted : Tuesday, 13 May 2008 4:36:20 AM(UTC)
Off the top of my head, they may have casting hole plugs in the top of them, usually heads with them have a threaded allen key bung in them, I would like to know why you ask this good question? Sorry, it has been a while since I have touched an engine lac
XFDAZA Offline
#3 Posted : Tuesday, 13 May 2008 4:55:35 AM(UTC)
XFDAZA
I have a slow coolant leak. I can see a drop of green coolant forming under the inlet manifold. Holdens have small welsh plugs under the manifolds to block off the coolant chambers. I thought fords may have as well.
#4 Posted : Wednesday, 14 May 2008 12:29:34 AM(UTC)
Yeah, I am pretty sure they do not, but I could be wrong. I had done many of these heads back in the day, Most of the time it was always around number 6 cylinder that the head corroded or sometimes it was only the gasket? Those models were quite common wi
#5 Posted : Friday, 25 July 2008 8:56:41 PM(UTC)
Yes they do... They are in the normal place. On the block below the exhaust manifold (Left hand side). Its best you replace all of them as usually if one rusts through it won't be long before the rest do. Its a difficult job as you will need to unbolt the
#6 Posted : Friday, 25 July 2008 9:06:48 PM(UTC)
Me again, found this one... this takes you through the steps and the welsh plugs are located in the same place too!
http://go.jeep-xj.info/HowtoWelshPlugs1.htm
