#1 Posted : Tuesday, 13 May 2008 6:20:25 PM(UTC)
I am interested to find out for the HQ range of cars where the parts for these cars were made.
As in panels, trim, engines,gearboxs,diffs etc.
Were they all made at the separate plants or were some parts made at specific places and then sent out to all the rest from there.
I seem to remember reading somewhere that all the engines were cast at the one plant is this correct.
Thanks for your help Paul.
#2 Posted : Tuesday, 13 May 2008 8:00:52 PM(UTC)
Hi hq ss
I will attempt to answer this, as there were many variations in supply.
All engines (except the imported 350 V8) were cast & assembled at Fishermans bend.
AFAIK, all gearboxes (M15/M20/M21/M22/M40) and diffs in the HQ era were made in th
#3 Posted : Tuesday, 13 May 2008 10:37:42 PM(UTC)
The panels would come from the one plant, final assembly of these would be at each plant, ie outer and inner guards would be shiped seperately then welded together at the vehicle assembly plant. This reduces size in shipping.
Yes trim was as Terry said
#4 Posted : Tuesday, 13 May 2008 11:12:13 PM(UTC)
ashlor motor was one of the trimmers did the trim in melb, ummm i think even up to WB, uniroyal and bridgestone did the dashpads and arm rest moulding
"ALL WE LEAVE IS MEMORIES.."
"ANYONE CAN RESTORE A CAR, BUT IT TAKES BALLS TO CUT ONE...."
#5 Posted : Wednesday, 14 May 2008 4:57:51 AM(UTC)
For two weeks of my school hoildays I scored a job where my dad worked. Nylex frankston Vic ,my job was to put metal caps, then a double ended screw in the back of the inner plastic shell of HQ dashpads .They where then sent off to be finsihed with the ou
#6 Posted : Wednesday, 14 May 2008 5:48:34 AM(UTC)
Ashlors continued to do work right up into the 90s, with such items as the VC SL/E wagon trim, VL Calais wagon trim, a lot of Brock stuff, as well as early HSV trims in the VN/VP era.
___________________________________________________
80737k Offline
#7 Posted : Wednesday, 14 May 2008 7:58:47 AM(UTC)
80737k
Gday Paul, I think its you that Anthony is looking to contact.
http://oldholden.com/com...reply/60735#comment-form
"Junk is something you throw out three weeks before you need it"
Fossil fuels are YUMMY !
80737k Offline
#8 Posted : Wednesday, 14 May 2008 7:58:47 AM(UTC)
80737k
G'day Paul, I think it's you that Anthony is looking to contact.
#9 Posted : Wednesday, 14 May 2008 10:49:38 AM(UTC)
Hi guys thanks for all the info it will explain some of the slight differences that I have
been coming across in relation to the HQ SSs.
Thanks 80737K. I have now replied to Anthony on O/H, I did not see his post when I checked my previous
posts ther
#10 Posted : Wednesday, 14 May 2008 10:49:38 AM(UTC)
been coming across in relation to the HQ SS's.
posts the
#11 Posted : Wednesday, 14 May 2008 4:23:55 PM(UTC)
AFAIK chassis numbers are consecutive for a plant and a model and an ADR update. ie Sydney starts at AHQ00001S and when there is an ADR revision it went to BHQ00001S.
The BODY plate is fitted early as evidenced by it being painted on some cars (plant s
#12 Posted : Wednesday, 14 May 2008 5:41:44 PM(UTC)
The chassis numbers are just coincedence, each plant numerbed sequencially and that is why each ends in a letter. Sydney and Melbourne ran out of numbers and reset to 00001, but Adelade and Brisbane did not.
The engien numbers however were simply seque
#13 Posted : Thursday, 15 May 2008 3:43:12 AM(UTC)
my SS is CHQ 183xxxxxx Adelaide car
#14 Posted : Thursday, 15 May 2008 10:08:24 AM(UTC)
Thanks Again guys.
Cloudy I will send you a email soon as there is a couple of things I want talk to you about.
The chassis numbers seemed a bit strange and because I have only been looking at the SSs I suspected that I was not seeing the overall pictur
#15 Posted : Thursday, 15 May 2008 10:08:24 AM(UTC)
Thanks Again guys.
The chassis numbers seemed a bit strange and because I have only been looking at the SS's I suspected that I was not seeing the overall pictu
#16 Posted : Thursday, 15 May 2008 4:13:40 PM(UTC)
Paul
Id put more emphasis on Holden getting it wrong. Send me the ID details and ill find out what it had fitted
Byron
#17 Posted : Thursday, 15 May 2008 4:13:40 PM(UTC)
Paul
I'd put more emphasis on Holden getting it wrong. Send me the ID details and i'll find out what it had fitted
Byron
#18 Posted : Thursday, 15 May 2008 5:10:05 PM(UTC)
Engines are manufactured as required, they arrive at the plant every day, they would make say 200 cars a day so stock pileing 50 engines, V8 and 6 cylinder would be no use. There is a masive planning process before a car goes down the line, so they know s
#19 Posted : Thursday, 15 May 2008 5:36:55 PM(UTC)
That makes sense Warren, as that is basically what happened with XU-1 ie the BODY plate says M20 but the box is a different ratio set to M20 but as the box is part of an option package on a standard GTR there is no change to the records. This may also exp
#20 Posted : Thursday, 15 May 2008 5:50:56 PM(UTC)
Actually Byron late LC and all LJ XU1s are fitted with an M20 gearbox.
The "official" wording is, its an M20 with new ratio set, but Holden is very specific in the workshop manual supplement, it is NOT an M21. This is just the code given by people late
Guest (26)
This page was generated in 0.094 seconds.
