#1 Posted : Sunday, 18 May 2008 8:58:56 PM(UTC)
I have a Hq 1 ton ute , It has a HZ twin front & HZ GTS yellow needle dash .
, bla bla bla
Anyway How hard is it to put a HZ indicator wiper stalk in
It has the little thin indicator stalk with wiper switch on the dash at the moment.
I just want someone to tell me if it is easy & what is involved.
I have the HZ coffee pot steering piece & i have the new HZ indicator wiper arm with 2 big Plugs on it
I have the blank out plastic for the dash & i have Brand new HZ ignition barrel & keys
Whats the plan of attack ? ( I'm not into wires) Serious answers only Please
Travis
#2 Posted : Sunday, 18 May 2008 9:28:06 PM(UTC)
It all bolts on, but there is only one cable out of the indicator stalk - the other is from the blinker mechanism which will connect straight to the HQ harness. You'll have to use the plastic bit around the column below the "coffee pot" off a HQ.
The w
#3 Posted : Sunday, 18 May 2008 9:28:06 PM(UTC)
It all bolts on, but there is only one cable out of the indicator stalk - the other is from the blinker mechanism which will connect straight to the HQ harness. Youll have to use the plastic bit around the column below the "coffee pot" off a HQ.
The wi
#4 Posted : Monday, 19 May 2008 7:09:00 PM(UTC)
K Cheers
This page was generated in 0.082 seconds.
