camlj Offline
#1 Posted : Tuesday, 27 May 2008 7:49:32 AM(UTC)
camlj
how easily does a 350 chev fit into an lj? obviously new engine mounts will be needed but do you have to notch anything to make it fit? does anyone make a conversion kit for them? thanks
#2 Posted : Tuesday, 27 May 2008 7:56:52 AM(UTC)
in the boot you mean? nup wont fit. You can get one in the back if you take out the back seats and passenger seat
HTH
#3 Posted : Tuesday, 27 May 2008 8:04:48 AM(UTC)
grind and weld the lips on the front end to clear starter on RHS, use 10.5 in flywheel set up, and oil filter area on LHS, or run remote filter, move column over to right on firewall, add extra knuckle on trunnion shaft from an LH-LX,as shaft must run as
